Old 08-27-2010, 09:33 PM
rad400 rad400 is offline
Default 4X heads
4X 7H heads what is the cc's roughly and what would the compression be on a 400? If they are 98cc's what would the compression be?
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 08-27-2010, 09:40 PM
1qikta's Avatar
1qikta 1qikta is offline
Conrad,
Most have 100-102 cc's stock. Depending on if you cut the heads look for around 8.0 -8.5. If you take 60 thou off you can get them to 92 cc's or so..
Good Luck.
I plan to sell a set this winter sometime...
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 08-27-2010, 09:41 PM
Craig Hendrickson Craig Hendrickson is offline
Pontiac performance Author
4X-7H are 400 4bbl with auto trans, 98cc, 2.11/1.66" and screw-in studs. Roughly 8.0:1CR on a 400.
I found this on John Wallace's website: WallaceRacing.com That's a good place to look first for stuff like this.
Craig Hendrickson, the "H" in H-O Racing Specialties.
http://www.OriginalHO.com
Old 08-27-2010, 09:47 PM
1qikta's Avatar
98'ccs is the "listed" CC but after testing a few sets you will think different.
Old 08-28-2010, 10:33 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
"ALL" of the Pontiac iron cylinder heads were built with larger than advertised chambers. As an average "Add" +- 4-8cc's to the claimed size. Among other explanations it gives a cushion for serviceablitity of the product. Perfect example: My current 1968 #16's are/were rated @72cc but measured 78cc. Do a search and you will see the small chamber d-ports measure between 76-82+ cc's from the factory.
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 08-28-2010, 11:22 AM
gtoformula's Avatar
gtoformula gtoformula is offline
Here's another Pontiac cylinder head website.
http://www.angelfire.com/on/geebjen/heads.html
Old 08-28-2010, 12:24 PM
David Holmberg's Avatar
Jay, you do know who "OriginalHO" is, right?
I suspect he's checked more than a few sets, among other things.
Old 08-28-2010, 01:40 PM
If one asks a simple question, one receives a simple answer. Note the use of the word "roughly" in the original question.
No offense taken to a more extensive answer.
So, what is the HP/TQ difference between 102CC and 92CC? It is about 10-12 increase (~5% for -10CC), everything else being equal. In other words, for every CC decrease, you will gain about 1HP/TQ (0.5%). You have to decide if all the other aggravations (shorter pushrods, milling intake surface, etc). are worth that relatively small amount compared to other changes like cam, headers, porting, etc.
I personally do not think so unless you have a NHRA Stock or SS class car and are looking for the last ounce of power.
Also, why not just change heads rather than throw $$$ at a set of 4Xs?
One more point: I happen to have a set of 4X 7Hs (1973 400 +0.030) on my 1976 TurboForce Firebird. Turbocharging it to 6-8 psi is worth about +200 HP/TQ (+80%) on the street. Supercharging would produce about the same increase. The last thing one would want to do with 'charging is INCREASE the CR.
Old 08-28-2010, 02:47 PM
1qikta's Avatar
David,
I understand. Since I am forced to run 4x's I have checked bout 15-20 sets(3h and 7h)...still have not found a 98cc set.
Sorry, Mr. H I wasnt paying attention...I still reference your book even today..Had it since the 80's
Old 08-28-2010, 02:56 PM
Jay, I was just kidding with ya.
Craig, Jay runs the FAST class, and is doing a very good job.
