Old 08-31-2010, 10:40 PM
gears1970 gears1970 is offline
Default '78 Trans Am HEI
I have a '78 Trans Am 400cid HEI Distributor I'm going to be rebuilding. What are the things I usually need to replace on an HEI?
Thanks.
Old 09-01-2010, 06:58 AM
JP_79Formula's Avatar
JP_79Formula JP_79Formula is offline
Default HEI
On mine, i replaced the usual: rotor, cap, coil, wires, plugs...
ran great for a month, then the HEI module died.
It took a while to figure out, there is a diagnosis link on this forum.
So, I would go ahead and replace the HEI module with the proviso
that you get an AC/Delco module. The repro ones have terrible failure rates.
Old 09-01-2010, 08:06 AM
wrenchmen's Avatar
wrenchmen wrenchmen is offline
very good reading here.......http://www.chevelles.com/techref/ftecref5.html
1970 Lemans Sport, PPR 383/4spd.
Old 09-01-2010, 10:49 AM
Thanks guys! Very helpful.
Old 09-02-2010, 10:27 PM
Grand73Am Grand73Am is offline
In that link to the HEI info, notice that you need to be sure to put the white heat sink compound under the module when installing one. A new module comes with a packet of it. But, if you are re-using a module, you'll need to get more heat sink compound. I had a hard time finding it at a parts store, but Radio Shack sells it in a tube, and you get more for your money.
The module gets hot and the heat needs to be transfered to the body of the HEI, so that's why you need the heat sink compound. If you don't have it or use something different, the module will go bad.
There's some bad info out there that says that dialectric grease can be used, but it's wrong.
Steve F.
Old 09-02-2010, 11:09 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
Take the distributor apart and check for slop; also clean all the carbon & crap off the shaft; it can slow down advance. Get some different springs for quicker advance -
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 09-04-2010, 11:42 AM
77 TRASHCAN's Avatar
The most important part to replace, if you take all the way apart, is the magnetic pickup. It is proven to fail, one of the two small wires will break, caused by the vacuum advance moving it. All the other parts can be replaced w/ the distributor in the car/engine.
When I take one apart, I check to make sure that there is no wear in the bushings. I polish the shaft and bushings to smooth them up. I gease both bushings. I slide the shaft into the top bushing, and before I engage it into the botttom bushing, I squirt a little motor oil into the housing. Sounds like overkill but the shaft is only lubed by oil vapor in normal operation.
Shut it off
Shut it off
