Old 09-13-2010, 02:54 PM
WillV's Avatar
WillV WillV is offline
Default 1997 Pontiac Montana - fuel injector question.
Rough idle this morning and the Service Engine light is constanly flashing now. It was on steadily before and I simply shut it off. I was getting an error code P0302. After some researching I'm concluding that it could be a bad #2 fuel injector. I know about releasing the fuel pressure first, but does anyone know if I can simply pop out the injector or does I need a special tool?
Will
Old 09-16-2010, 08:47 PM
Release a clip and yes it'll come out later you pull the fuel rail up.
former." --Albert Einstein
- Winston Churchill
Old 02-21-2011, 03:14 PM
Ollie's Avatar
Ollie Ollie is offline
Yes they push in, might be a good idea to have a full set of top and bottom "O" rings when you reassemble the fuel rails. put a little dab of lite grease on the "O"rings to help reinstall the injectors.
Its ok to giggle and snicker, Dont laugh and point
