We've had a few requests here on the forums to start a Tech forum to archive some good informative tech threads that usually have plenty of pictures to help illustrate what's going on. I can't create a separate forum for them but I can start a thread and stick it at the top of this forum with links to different helpful tech threads.
Please reply here to this thread if you find a thread that was started to offer some good tech info and I'll add the tech thread that you've linked to the list. I'll start it off: Pontiac Tri-Power Carburetor Information https://forums.maxperformanceinc.com...d.php?t=838404 SOME HOLLEY TUNING TIPS http://forums.maxperformanceinc.com/...d.php?t=811891 Boosting Devices and Methods for Street & Strip https://forums.maxperformanceinc.com...d.php?t=830273 How to rebuild a Pontiac V8 http://forums.maxperformanceinc.com/...d.php?t=623671 PONTIAC Cylinder Head Tech - Early vs Late http://forums.maxperformanceinc.com/...d.php?t=636024 PONTIAC Cylinder Head Tech - Round-Port vs D-Port http://forums.maxperformanceinc.com/...d.php?t=636309 Gain clearance for headers to oil filters http://forums.maxperformanceinc.com/...d.php?t=468168 My Doug's Installation............. http://forums.maxperformanceinc.com/...d.php?t=550283 Log Exhaust Manifold Tech http://forums.maxperformanceinc.com/...d.php?t=630943 Comprehensive Tremec TKO tech tips guide for GTO's http://forums.maxperformanceinc.com/...d.php?t=466818 Comprehensive Tremec TKO tech tips guide for '67-'69 Firebirds http://forums.maxperformanceinc.com/...d.php?t=466820 Comprehensive Tremec TKO tech tips guide for '70-'81 Firebirds http://forums.maxperformanceinc.com/...d.php?t=466821 Disc Brake Install Tutorial -PICS - Front Discs for $ ~150.00 http://forums.maxperformanceinc.com/...d.php?t=593740 Distributor Grease http://forums.maxperformanceinc.com/...d.php?t=652883 DIY Junkyard Serpentine Belt System http://forums.maxperformanceinc.com/...d.php?t=690512 New Pontiac 455 engine build video http://forums.maxperformanceinc.com/...d.php?t=721003 Hurst Wheels - Anatomy http://forums.maxperformanceinc.com/...d.php?t=748138 Pontiac 9779068 Cam http://forums.maxperformanceinc.com/...d.php?t=765522 541596 421 Super Duty McKellar #10 Camshaft http://forums.maxperformanceinc.com/...d.php?t=770467 Oil Pan Mods http://forums.maxperformanceinc.com/...d.php?t=609229 Valley Pans http://forums.maxperformanceinc.com/...d.php?t=769185 Measuring for pushrod length http://forums.maxperformanceinc.com/forums/showthread.php?t=771081 Pulled the trigger on a 2004r tranny. Which dipstick tube for 1970 GTO? http://forums.maxperformanceinc.com/...d.php?t=771081 389 vs 421 Blocks http://forums.maxperformanceinc.com/...d.php?t=772995 Installing front sheet metal http://forums.maxperformanceinc.com/...d.php?t=773122 Using a Tri-power with a non-dimpled timing cover http://forums.maxperformanceinc.com/...d.php?t=739781 Small Bore = Big Power Cheap? http://forums.maxperformanceinc.com/...d.php?t=730569 Intake Manifolds - How Much Do They Weigh? http://forums.maxperformanceinc.com/...d.php?t=772223 Simple Fix For Today's Clutch Fan Running Hot http://forums.maxperformanceinc.com/...d.php?t=776003 Adapter plates and engine plates http://forums.maxperformanceinc.com/...d.php?t=732389 1964 421 HO Build http://forums.maxperformanceinc.com/...d.php?t=771741 389 vs 400 as basis for stroker build http://forums.maxperformanceinc.com/...d.php?t=702961 Who has shipped cast iron heads and how did you do it???? http://forums.maxperformanceinc.com/...d.php?t=789474 Which brake shoe is the primary? http://forums.maxperformanceinc.com/...d.php?t=828937 |
Bart,
We REALLY DO need a "Library" location for Tech Threads somewhere easier to find that looking around like a chicken with his head still tucked under his wing! Every time I look for these for someone, I have to look up your "Threads Started" info. Charles |
BTW, is there one somewhere for redoing bucket seats?
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Here are some Threads I added to my favorites when I was rebuilding my 350.
1st time engine builder here, leave me tips http://forums.maxperformanceinc.com/...eaning+threads A couple assembly and break-in questions http://forums.maxperformanceinc.com/...d.php?t=593983 Dipstick tube in block question http://forums.maxperformanceinc.com/...=dipstick+tube Drilling block for improved cooling http://forums.maxperformanceinc.com/...d.php?t=583733 Help: proper valve stem seal assembly instructions. http://forums.maxperformanceinc.com/...perfect+circle HEI tunning tips http://forums.maxperformanceinc.com/...ebuilding+tips Pontiac engines are NOT like Chevies... http://forums.maxperformanceinc.com/...t=valve+length top 5 things to check my engine builder on. http://forums.maxperformanceinc.com/...ght=main+bolts Another Timing Question (Center Plate and Weights) http://forums.maxperformanceinc.com/...ht=139+weights There are more on my other computer
1970 Lemans Sport, PPR 383/4spd. |
I am looking for some advice on the engine I am building for my car. First of all I am looking for a a smooth idle (it is a convertible) with as much torque as possible on a budget. I am looking for a recommendation as to which parts I should use from what I have to get a good low to mid range power. This car will be a cruiser not a race car.
The block I am using is a 1973 Pontiac 400 X5 block...stock bore. I have 2 sets of heads... 1)1973 4x heads- I believe 2.11 intake/1.66 exhaust and 98CC 2)1970 11 heads-I believe 1.96 intake/1.66 exhaust And I have 2 intakes 1)Holly Street Dominator single plane 2) Pro Comp Air Gap dual plane I will be using an eldelbrock 4 barrel carb Again I want a smooth idle and a good low to mid response. The best fuel economy possible would be nice too. Which combo should I use? What would be the best cam to use? Thanks for any advise anyone has. |
Compression, Cylinder Pressure and Cam Selection
http://216.178.81.108/forums/showthr...ht=compression |
Wow this is long overdue. My apologies.
Gavin posted this in race section and I've added info and pics.http://forums.maxperformanceinc.com/...d.php?t=732389 |
Hey Guys,
Excellent info and ongoing investigation on the #670 castings, by Rocky Rotella. http://forums.maxperformanceinc.com/...ight=670+heads
Poncho Huggen, Gear Snatchen, Posi Piro.
Bart, is there a process to download ( I did download & print like 15 years ago but...forgot); Downloadable as text (with images), so we can assemble our own Tech Ref books.
This is great, lots of great information here. At least two threads that I’ll be reviewing tonight. Thanks b-man.
| The Following User Says Thank You to Green Elephant For This Useful Post: | ||
