Old 09-20-2010, 08:45 AM
knauert1's Avatar
knauert1 knauert1 is offline
Default ride height
Hello, advise......... I own a 1968 triple black GTO ragtop in stock/premium condition, I realize that it is worth the most as it sits right now but I am not planning on selling it so I want to change it to be to my liking, I installed a Bendpac HD-9 lift in my garage to help me with this project and am planning on installing Wilwood 4-piston red drilled/slotted big brake kit on the front and rear along with Foose Legend 18" wheels, my question would be when I install all of this I have a feeling that it will not sit right (height wise) and was looking for advise as to what experience anyone has had with doing this, do I need to drop the front spindles 1" or 2" (which), do I need to purchase new springs dropping entire car 1", any advise/suggestions will be greatly appreciated
Tom
Old 09-22-2010, 12:53 AM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
For the wheels, what fits a Chevelle does not always work with a 68-69 Pontiac in the front. Chevelles have larger front wheel openings and different internal structures in the rear.
What width wheels do you want to run?
Do you only want a 2 inch drop or do you want to set the fender a specific height above the tire?
More than an inch or two takes a little more than just springs to make the front suspension work. If you want to change spindles I would recommend the AFX tall front spindles and use a brake package to match. This would lower the car about an inch in the front and really improve the handling to match the new brakes and tires.
Here is my 68 with 18x9 front and 18x11 rears:
Let me know if you have any questions about my setup.
Jon
1968 GTO with SC&C Suspension
Old 09-22-2010, 08:22 AM
knauert1's Avatar
Jon, I like the way your car sits as well as the other cars in picture, I do not know how much I need to drop car, I am looking at the Foose legend 17x8-18x8 front, 18x9 rear so I dont think that width will be an issue with fenders, my concern is that when I put on these wheels it will not look right (sit too high), it has 14" stock wheels now and sits high as it is, I cannot figure out how to attatch pictures to this website, I am only familiar with Jpeg format not http:// format, if you can send me your e-mail address I can send you pictures or tell he how to convert from jpeg to http://
thanks
Tom
