shifter cable question help!
ok i just got the trans in the car and i bought a cable off my friend and installed it and it goes through the gears fine but its not going in park ive been reading about the park pawl and im nervous it worked fine before. it moved through the gears by hand no problem could it be a routing prob or what? thanks guys
WAKE UP ITS TIME FOR A REVOLUTION! |
Put the car in park when you install the cable assuming there is an adjustment on it.
theres three things needed to adjust in order to get the shift cable installed right.
NSS on the column shift lever pin on the trans backdrive linkage all three impact each other, if one is way off you'll never get the other two to work right. two sections of the manual cover this, the trans and electrical sections, with the electrical section for the NSS. in a nutshell this is it - adjust backdrive to obtain "full" park. (with cable detatched from trans) put shifter in N, place trans selector in N, attach cable to pin on trans selector. that being said, if you dont have the right cable ( too short ) you'll never get it to work right, also, without the correct trans shift lever, youre doing # 1 into the wind or up a rope....
costs too much |
right on!
i think i have thanks a lot guys!
