Old 10-04-2010, 10:24 PM
Pontiacman469 Pontiacman469 is offline
Default 62 Haeds
Are the "62" heads worth 10 cents or no?have a chance to by a set for my 455.Unsure of exact year,just said off mid 60s 400 with screw in studs.Thanks
Old 10-04-2010, 10:39 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
62 heads are nice heads.big valve(2.11-1.77)screw in stud,nice chamber,but it is a smaller chamber advertised about 72 i believe but most are found alittle bigger 75/78.even at the bigger size they would give a pretty high compression on a 455 if you don't run dished pistons.if you are looking for a strip set up where you would use race gas,not so much of a problem.
they can be found between 100-250 a set that need redone and up depending what has been done to them.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 10-05-2010, 08:08 AM
Mr. P-Body Mr. P-Body is offline
62s are '69 400/428 heads. As Warbird said, large-valve, small chamber. Pretty much the "same" as the other iron d-ports of the era. Not a "bad" head.
Jim
Old 10-05-2010, 09:28 AM
MandevilleBird MandevilleBird is offline
If in need...I have one, ready to bolt on. Will throw in second free!(failed porting attempt) LOL
Old 10-08-2010, 08:14 AM
74Grandville 74Grandville is offline
depending on the type of 455 engine you're building, you'll need a 30cc dish piston to keep the compression down.
Old 10-08-2010, 08:47 AM
Ollie's Avatar
Ollie Ollie is offline
Check in the Performance Parts For Sale. Firebird Crazy 1959 is offering two sets of bare 7K3 heads for $100.0 a set. If he wasn't so far away I would get a set for my 455. These are the last of the big valve heads with screw in rocker studs. Listed at 96 cc combustion chamber, on a 30 over 455 this will have a 9.14 cr. Perfect for a pump gas street motor. I know they don't have the end exhaust bolts holes. If you don't run headers they will be ok, with stock log manifolds or Ram Air Manifolds
Your location is listed a Maine, Firebird Crazy lists his location a White Lake N.Y. I think if I was in your position, it would be road trip time.
Its ok to giggle and snicker, Dont laugh and point
