Old 10-06-2010, 04:00 PM
jrainieri's Avatar
jrainieri jrainieri is offline
Default Big car tires
The GP could use a new set of shoes---- tires are a bit old. Have been asking around and 225/75-14 just aren't around anymore. I have seen a few big cars with 215/75 and they just look too small. Anyone out there with any leads on an old stash of this size or other ideas? Even Coker can't get them!
Knowledge is knowing a tomato is a fruit; wisdom is not putting it in your fruit salad.
Old 10-06-2010, 04:27 PM
Coach's Avatar
Coach Coach is offline
Do you need radials?
If not look at the pics of my car from the link in my sig. I really love the look of bias-plys on these old cars. The set on mine came from Coker and are original spec tires.
-H
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
Old 10-06-2010, 05:14 PM
jrainieri's Avatar
I really like the handling improvement you get with radials. I had polys on a 63 GP I had some years back-----I thought the car needed a new front end when I first drove it. Had it checked out, everything was good, put the radials on and never looked back. Had them on my Goat as well.
Old 10-06-2010, 07:39 PM
Coach's Avatar
I totally understand. If this car was a regular driver I would do the same.
Best, Harry
Old 10-06-2010, 08:42 PM
stevep's Avatar
stevep stevep is offline
If you want to spend $800.00 per set, you can get American Classics. You can even get them in 235-75R-14.
You could also convert to 15" wheels and get 225-75R-15'S.
Old 10-06-2010, 08:47 PM
Stuart's Avatar
Stuart Stuart is offline
Coker still lists a couple radials in that size. http://store.cokertire.com/catalogse...t/?q=225/75R14 They aren't cheap, though.
Old 10-07-2010, 06:05 AM
jrainieri's Avatar
I was looking for a 1" WW.
Old 10-07-2010, 08:48 AM
jrainieri's Avatar
The American Classics may be best option---can I anticipate any fit issues using 235's?
Old 10-07-2010, 09:16 AM
stevep's Avatar
I have the 235's on my 60 with no issues plus a friend has them on his 64 GP and he said there fit fine.
The 235's are probably around the same size as 8.55-14's.
I had mine delivered to Carlisle and saved a few bucks. The drive very well...for now!
You could also put on a set of 15" Rally II's. Or get a set of 15" steel wheels and use the 69-74 15" spoke hubcaps. They look almost exactly the same as the 14" spoke caps that could have come on your car. The 15" tires are readily available.
I would stay away from the Coker's.
Old 10-07-2010, 09:22 AM
jrainieri's Avatar
Steve--which distributor did you use?
Old 10-07-2010, 02:01 PM
67GP428's Avatar
67GP428 67GP428 is offline
I have 235/70/15 on my 67 GP and have no issues. My car came with H70/15. I bought my tires from Diamond Back Classic Radials. It's a Diamond Back LS5 made by Cooper tire, made in the USA. Think most of Cokers are my down south. Scott
Old 10-07-2010, 08:55 PM
stevep's Avatar
It was 1.5 years ago, so I don't remember. There were 2 suppliers listed in Hemmings that carried these tires, 1 was Coker and it wasn't them. I think it may have been a company in PA or Ohio.
Diamondback did not have what I wanted.
Old 10-26-2010, 02:42 PM
schlitzman's Avatar
schlitzman schlitzman is offline
Default Radials on 8-Lugs
Also looking for a set of right size radials for my '67 GP. Can you use the P235/75R14's on 8-Lug wheels? Will these larger tires have a significant drag on performance?
Thanks,
Bruce
Old 10-26-2010, 04:36 PM
stevep's Avatar
Default A little late but..
I used Universal Tire because they gave me a better deal than Coker.
I still think that the best bet on a 67-up is to use 15" wheels and either 15" wire wheel covers or 15" Rally II's. That way you can get a good set of 225-75R-15 tires that will last for about $300.00.
Old 10-26-2010, 04:38 PM
stevep's Avatar
Thanks,
Bruce
That is what I usually use with 8 lugs and they work fine. The 235 75-R14 is about the same diameter as the 855-14 that came from the factory. The speedo on my 60 is just about dead on.
Old 10-26-2010, 06:23 PM
jrainieri's Avatar
I actually found some 215/75-14 Cooper Trendsetter SE tires, 3/4"WW----$85 each including mounting/balancing at my local tire supplier. 215/75 are less than .6" less in diameter than the 225/75. Can't really notice a difference in the wheel well or speedo.
Old 10-26-2010, 10:25 PM
225/70R14 BFG Silvertowns... it had 225/75R14 whitewalls when I bought it from the original owners son
Old 10-27-2010, 01:39 AM
J_JAMNIK J_JAMNIK is offline
Smile
You could also convert to 15" wheels and get 225-75R-15'S.[/QUOTE]
I did this on my 68 Bonneville wagon and have no regrets. 14 inch tires are slim pickin's now days and the load ratings are not the best for big cars.
Junk is something you've kept for years and throw away three weeks before you need it!
Old 10-27-2010, 02:18 PM
carmak's Avatar
carmak carmak is offline
My 67 Catalina had clearance issues with 235-75R-15 on the front. Typically when turning tight into an uphill driveway. The wheels were RallyII's off of a 69 Bonneville.
The pic below show my 67 with the RallyII's. I think it was taken in 1992. The gold Catalina is a friends and the blue 65 was my 2+2 with a 3spd on the floor. I miss them both
Carmak
Riverside, Iowa
Old 10-27-2010, 02:45 PM
stevep's Avatar
I have 225-75-R15's on my 67 GP with a slight rub on a real tight turn.
