Old 10-15-2010, 09:23 PM
codyyy's Avatar
codyyy codyyy is offline
Default Installing rear control arms help
I'm trying to get the control arms installed in the '68. I did this before with the old coils however I believe they are probably shot and that's why I could line them up. I'm having trouble lining the holes up on the upper control arms in particular. I've tried jacking up the rear end, lowering it, putting weight on the frame, using a come along to pull the rear axle inward etc. What do you usually do? These are new coils and I don't have the body on the frame yet. Thanks.
Old 10-15-2010, 10:17 PM
grrr421 grrr421 is offline
how are they not lined up? Do you need to rotate the pinion up so the ears line up ?
or is it a left right thing?
Old 10-15-2010, 10:24 PM
codyyy's Avatar
It is mainly the passenger side upper. It needs to go a couple millimeters to the 2 o'clock position if you are looking at it straight on. No matter what I've tried it still will not line up. I'm almost just thinking of either dropping the body on it or making some adjustable upper and lowers.
Old 10-16-2010, 11:17 AM
chrisp chrisp is offline
If the coil springs are installed , remove them , get all 4 arms bolted in then install the new coil springs .
Old 10-19-2010, 05:09 AM
78 GHOST 78 GHOST is offline
Yup, during my frame-off I installed the control arms without the coils. Then, after the control arms are in place, you can install the springs.
The upper diff. attach points were particularly a pain in the derriere'. IIRC, I installed the uppers to the diff. then was able to get the leverage to tweak them into place on the frame. I think I did the uppers, then the lowers, then the springs.
I always tackle the worst part of the job first.
Good luck Cody.
-Matt
____________________________________
"I work in high speed aluminum tubing."
Old 10-20-2010, 09:49 PM
shotgun shotgun is offline
PY Staff -Tech
Do the uppers first.
I use 2 rqachet straps around the rear to the frame up front and pull the rear until the lowers line up and slide the bolts in.
Did 20 cars this way without issue.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 10-27-2010, 01:29 AM
J_JAMNIK J_JAMNIK is offline
I agree with doing only the uppers first and without the coil springs in place. You have to make adjustments on left and right as well as angle of the pinion input up and down.
Junk is something you've kept for years and throw away three weeks before you need it!
