Old 10-24-2010, 08:11 PM
Joel Koontz Joel Koontz is offline
Default Any Cub Cadet Experts here?
I have a 3165 Cub Cadet that has the shaft drive Hydrostatic Transmission.
It had a leak from the bottom of the rear axle housing and I removed the rear end cover to try to stop the leak. I put it back together with some silicone sealer and then drove it to my shed to park it. As I pulled it into the shed I noticed that the trans and power steering were acting up and I just got it pulled into the shed as it quit moving and lost power steering.
The rear was full of fluid and the only thing I could think of was that I must have sucked up a piece of silicone and it was blocking a passage somewhere in the system. I assumed I was going to need to tear the entire trans down.
I pulled the entire trans/rear out of it (took about 2.5 hours) and then pulled the rear axle cover off. No loose silicone, but I did find what was causing the problem. I apparently left a paper towel in the rear axle and it got sucked into the pump pickup. I felt like one of the Surgeons that left a sponge in a patient. The paper towel is intact so I don't think any if it went through the system, I think it was just starving the pump of oil.
I drove the tractor about 100 yards before it stopped moving and I probably left it running for another 30 to 60 seconds trying to figure out what was wrong.
DID I BURN ANYTHING UP IN THE PUMP/TRANS?
I don't want to tear the pump/trans apart if I don't need to, but by the same token, I don't want to spend 5 hours putting it back in and tearing it out again, if it is definately damaged.
Any way to test the pump without putting it back in the tractor?
Old 10-24-2010, 08:18 PM
try mytractorforum.com
the nicest people you'll ever "meet"
Old 10-25-2010, 06:51 PM
6ragtop8's Avatar
6ragtop8 6ragtop8 is offline
Default oil problem
Hi Joel, I am no expert on Cubs but I work with a guy who collects old Cubs. I asked him about your delema, He said it SHOULD be fine. What you do is your choice. Just trying to help.
Old 10-25-2010, 09:23 PM
Thanks for the replies.
I called the local CC Dealer and talked to Mechanic today. He said that no longer than I ran it, he thought it would probably be OK.
After work I started putting it back together and just finished getting it back together enough to start it up. No test drive (no fenders/seat or gas tank) but I started it long enough to confirm that I got power steering and forward/reverse so I think it is probably OK and I will finish reassembly tomorrow.
Old 10-26-2010, 02:28 AM
andyleonard's Avatar
andyleonard andyleonard is offline
I cracked the case on mine and ran it longer than that before it quit moving. Welded the case up, new oil and it runs fine.
