Old 10-27-2010, 06:29 AM
steve's Avatar
steve steve is offline
Default Power steering
My firebird came with manual steering. I have a bunch of power steering components and have been considering the upgrade to power steering. Has any one else done the swap ? It seems pretty straight forward and easy. Are there issues in doing the swap I am unaware of ? Was it worth it ? The only time I miss power steering now is when trying to park in tight spaces....
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 10-27-2010, 07:26 AM
Ballast's Avatar
Ballast Ballast is offline
I just did it on a 64 GTO. Was it worth it? Hell yes. I hated that manual steering, way to slow and way to hard to park. Could hardly do a left hand turn and haul it in before the centerline - right hand turn in your case Steve.
I got the box from Chip at Power Steering Services and he was good to deal with, the box has decent road feel.
The only issues were lining up the serpentine pulleys ( they didnt), getting the hydraulic hose bloke to put the hoses to the right spots on the box, and getting all the air out of the system.
I have a engine similiar to yours and was worried I wouldnt be able to correct it quick enough if it stepped out. Dont worry about that anymore,
cheers
Steve
Steve
Old 10-27-2010, 07:31 AM
steve's Avatar
What did that box cost ya ? Any special ratio ? Was it hard to get the manual box off ?
Old 10-27-2010, 07:36 AM
chrisp chrisp is offline
Better try to find a pitman arm first , the power steering box uses a different pitman arm . I think they are tough to find . All else is readily available .
Old 10-27-2010, 08:28 AM
Ballast's Avatar
Chip charges $325 with a core. $425 without. I got it shipped to oz, but still good value. You can check on his website powersteering.com
3 turns lock to lock.
Yes the pitman arm is a different size, and the rag joint was also. The man rag joint is smaller than the two sizes I know of for the PS boxes. And I know there are two rag joint sizes for PS boxes cos I ordered one and it fit a PS box I had, but it didnt fit the one I got from Chip. I managed to find another rag joint bracket that fit Chips box. I should have just got the rag joint from off Chip so i knew it would fit.
Getting the box off was easy enough - I borrowed one of those wedge forks to release the pitman arm from the centerlink, and a tri-puller to release the pitman arm from the box.
Steve
Steve
Old 10-27-2010, 08:42 AM
Leftyarmstrong Leftyarmstrong is offline
When I bought my car the ps was missing. Took awhile to gather up the stuff. Hell yes. Put an aftermarket kit on my truck. Expensive. Alot of work. Hell yes. Why do you think I was calling myself leftyarmstrong when I signed up here? Injured my right shoulder and had to steer with my left. Power disc brakes too. It was among the first things. My wife came home one day and asked if I'd put that power disc kit in yet. I said no. She said "we should get that." Next day I was at http://www.abspowerbrake.com/. Give them a call. They do steering too.
1965 Pontiac Lemans Convertible, 1957 Chevy 3600 dump bed, 1968 Ford backhoe.
http://picasaweb.google.com/orchidsk...vyiKGThcblmQE#
Old 10-27-2010, 08:45 AM
Have a good 3 turn power box if needed .
Old 10-27-2010, 09:36 AM
Just remembered this: Guy with a '65 Buick asked me about my close ratio box. Said he'd tried it and didn't like it because it didn't want to return on its own. True enough. The close ratio I installed tends to not return on its own and it is a bit annoying. Anyone else have that experience?
Old 10-27-2010, 11:34 AM
steve's Avatar
will the power steering brackets bolt onto Eheads without mods ?
Old 10-27-2010, 11:46 AM
BVR421's Avatar
BVR421 BVR421 is offline
Upgrade? maybe if grandma is going to drive it.
what a bunch of weenies! I suppose you namby pambys want AC as well?
Old 10-27-2010, 12:09 PM
steve's Avatar
thanks. very insightful
Old 10-27-2010, 12:32 PM
Funny you should say that. After restoring my '57 3600 dually with a dump bed, my 86 year old mother came over to borrow my F150 to move an antique. I said, "No way. YOu have to take that one." pointing to my stovebolt Chevy. She looked at me and said, "I'd be proud to drive that truck."
Old 10-27-2010, 01:46 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
its possible its the pump.
ive read over the past couple years on these close ratio/hi-effort box swaps that the pump needs to be matched to it. matched in the sense of the pressure valve in the pump.
i dont know if doing that increases or decreases the fluid pressure to the box, logic sorta says the "low effort" boxes are thay way due to high fluid pressure. but who knows....
i also dont know what role, if any, line pressure plays in the steering wheel return of saginaw style boxes.
if it does play a role, and IF high effort boxes require higher pressure than low effort, i guess it's possible the pump doesnt have enough oomph to help that along.
costs too much
Old 10-27-2010, 05:36 PM
J_JAMNIK J_JAMNIK is offline
Did the conversion on a 67 FB. Made the car a lot easier to drive(manual trans) especially once the power brakes were installed!
Junk is something you've kept for years and throw away three weeks before you need it!
Old 10-28-2010, 01:40 AM
Schurkey Schurkey is offline
More! Positive! Caster!
Negative caster makes the steering easier to turn. Spec'd for manual steering.
Positive caster makes the steering return to center; and makes for more-stable high-speed highway cruising, but Grandma can't turn the wheel to park the car unless it has power steering.
Old 10-28-2010, 09:28 AM
Ballast's Avatar
All this fixation on grandma's makes me think you seppos have a wrinkle fetish.
Is power steering a more pleasurable experience - hell yes. Thats all the bloke wants to know.
Steve
Old 10-28-2010, 09:49 AM
steve's Avatar
ha. these guys just like to yank your chains. they probably have all power accessories and AC on their grocery getters so they are comfy when they are out picking up feminine napkins for their women.
Old 10-28-2010, 10:08 AM
HA! These days something is wrong with the wife's thermostat. AC is next.
Old 10-28-2010, 08:33 PM
Ballast's Avatar
Yep, thats what I figured.
cheers
Steve
