S-D Performance anybody with experience?
I have a 68 intake that i removed all the heat & choke set-up and litened it up about 25 pounds and wanted to send it to S&d Performance for a complete intake make-over and see if any, any real performance gains over my RPM witch i have on my motor now. Anybody running one of there intakes and are you happy with everything they did??? I see they follow Cliff Ruggles ideas and my rpm intake right is not port matched. So whats your thoughts and i try and read every reply. Thank You! P.s./ I might just remove the RPM and port match it being water crossover is removed and see what happens. 67 gto 373 gears headers rpm intake 400 turbo trans with Continental conver.JUST A WINTER PROJECT ON THE INTAKE!!
Do a search here for SD ....great reputation.
Highly recommend them. Just give them a call and see what they advise doing....they'll give you good,honest advice...
72 G.T.O. 455HO Auto 69 Firebird 400 Conv. Auto. IAII 540 and damn vroomy.... |
www.sdperformance.com I sent them an email, a couple of years ago, got an answer in less that 24 hours....
But is anybody running there cnc ported intakes and how are they performing??
I would not hesitate to use them.
Pontiac Dude is running their E-heads and intake, with a hyd roller running mid 9's.
Do sharks sh!t in the sea? Of course SD Performance is great, they port matched and cleaned up my HSD intake !
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
dave has emailed with me quite a bit and helped me a lot. he has been very good!
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
I had SD performance do the works on my factory 70 intake cnc port,hand blend,plenum mod and seperate water crossover.I can feel the difference, pulls harder.This intake compliments my SD performance cnc ported 263 cfm #64 heads nicely.SD does great work.
2001 Trans Am,WS6 Sunset Orange Metallic (sold) 1973 Trans Am 455,4speed 1970 GTO |
What heads are you running? Any porting?
Cliff did testing and found only upon porting his KRE D ports to a certain level did the RPM take over his modified stock intake. Otherwise below that level, the modified stock intake was better.
68 Firebird Are you running with the wind or breaking it? |
"SD Performance is great, they port matched and cleaned up my HSD intake !"
Very nice guy. I agree he has the capability to do good things with the HSD intake. Years ago he worked a Holley Street Dominator intake for me, port matched (2.300" tall port opening), runner blending and some plenium work. Dyno tested on a previous 462 it made only 11.5 less horsepower than a port matched Victor intake, and only 6.1 ft.lbs less torque (these were peak numbers). And also he re-worked another HSD intakes carb flange to accept a Dominator carb with similar port work, back-to-back track tested with a HP8896 Dominator carb it ran 10.74 at 126.03 mph vs 10.68 at 126.61 mph for a Victor intake using the same carb. That all said, he did tell a friend recently he was way too busy to do similar work on his HSD intake. The situation should be differant on another type of intake especialy if a cnc program is involved. |
dude pm sent too.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
SD Intake Porting
Love SD Performance. Dave hand ported my Edelbrock EFI manifold to match the flow of my SD ported E-heads. Makes a ton of power. Very good people.
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme. |
I thought he went a .60, that would be "mid" right?
They rock!
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
Dave is the Man!! His combos rock! and He Cares and loves pontiacs! Next question are your heads ported? U really need to get back to the track and get some more baselines first before all this switching stuff around or u will never know what works and what doesn't!
you running a 455 or 400? if your just planing on running 13's or 12's just use it "as is" what cam and heads are you running?
Dave Bisschop and SD Performance are a first class act. You will not deal with a nicer or more knowledgeable guy in the Pontiac community. I wholeheartedly recommend SD. I run a set of his WP's, ported Victor, and custom spec cam. I gained better than a full second ET and 11+ MPH.
69 'Blackbird' 535 CID IA II SD Wide Port E-head Pro Systems Dominator |
Awesome Les!! Yep Daves combo's are the ****!!.. Welcome unofficially to the 11 sec club
