Old 10-28-2010, 07:30 PM
njsteve's Avatar
njsteve njsteve is offline
Default Help: I need a brake proportioning valve
Anyone have the cast iron disc brake proportioning/combination valve for a 71 and up T/A? I believe that other GM cars of the same era used this same valve. The replacement offered by the aftermarket is brass and looks nothing like the original.
I just noticed that mine is seeping fluid from the red arrow location. Luckily I use silicone brake fluid so no paint is damaged, but it is pissing me off, as well as being a major safety issue.
I dont see anyone selling these anywhere. You can find them for the Ist Gen F-bodies but not the 2nd gens.
Old 10-28-2010, 08:19 PM
Wick's Avatar
Wick Wick is offline
It's been a long time since I had that style apart but isn't there an o-ring behind that?
_____________________________
She woke up sunny side down and I was still thinking I was too proud to flip her over
Old 10-28-2010, 08:41 PM
Young Pontiac Guy's Avatar
Young Pontiac Guy Young Pontiac Guy is offline
I am pretty confident that there is a o-ring behind there. I took mine apart for curiosity to see how it worked. Should be replaceable. Might even be able to find a rebuild kit for it.
Joel
Old 10-28-2010, 08:42 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
can a brass one be milled and machined then blasted to look like an original one?????
just a thought....
Old 10-29-2010, 12:21 AM
Formulabruce's Avatar
If I dont end up with a nice one, Im sure Franks Pontiac parts ( http://frankspontiacparts.com/ )will have a nice one, or Steve barak at pontiac heaven
http://www.pontiacheaven.org/
Both are in rust free areas..
PS ever seen the DOT #3 synthetic fluid? I use DOT 5 but just saw some with dot 3...
" Long may we DRIVE !"
Old 10-29-2010, 07:25 AM
165th's Avatar
165th 165th is offline
Steve, Billy at White Post restorations may also be able to help you. He may be able to restore that one, or provide a replacement.
Old 10-29-2010, 07:38 AM
x-bird2 x-bird2 is offline
http://www.mpbrakes.com/index.cfm
Give them a call and ask for Carmen. he may be able to a rebuild for you. He hooked me up with mine years back.
Old 10-29-2010, 09:02 AM
CaptCrunch CaptCrunch is offline
See if Bill Oxley will rebuild it for you.............
Old 10-29-2010, 09:18 AM
njsteve's Avatar
He can, but I need a spare to send him. I don't want to leave the brake system open to the elements while I get the valve rebuilt. He said there is an o-ring in the leaking area that is probably the culprit.
Old 10-29-2010, 01:50 PM
Maybe cap em in the mean time.........you already have air in the system........Bill did all my brake parts including the calipers and his work is superb...........
Old 10-29-2010, 05:11 PM
importsmasher's Avatar
importsmasher importsmasher is offline
I have one off of a 73 Grand Prix; worked fine a year ago when I pulled it. I suspect it is the same; if you are interested, PM me.
Importsmasher
Old 10-30-2010, 06:29 AM
tommie69's Avatar
tommie69 tommie69 is offline
Wink
Steve
I had Bill rebuild mine when he did the master and booster.Give him a ring!
Old 10-30-2010, 10:38 AM
sd455hota's Avatar
sd455hota sd455hota is offline
Default prop valve
I have one for you. I have a couple more I planned on sending when I got time. He's done some others for me. He does a great job. I'll find Bill's address and get them off asap since you need it soon. You can contact him and let him know your in a hurry for yours so he'll get it quicker.
Bill if your watching send me your address again in case I don't have it. [email protected]
Old 10-30-2010, 11:46 AM
johnsma22's Avatar
johnsma22 johnsma22 is offline
FWIW, DOT3 and DOT4 brake fluid absorbs moisture by design. No matter how tight you think your brake system is, moisture will and does get in. With glycol based brake fluid, which is hygroscopic, the moisture is absorbed into the entire volume of fluid. Over time this will mean replacing the brake fluid. Silicone brake fluid does not absorb moisture. While this seems to be an advantage, it isn't. Because the moisture is not absorbed into the fluid it ends up in the lowest point of the system, the calipers and wheel cylinders. As you know, water boils at 212˚F, so therein lies one of the problems with DOT5 brake fluid.
Another problem with silicone brake fluid is the fluid itself is compressible. That leads to a spongy pedal feel. I've never felt that the fact that silicone brake fluid doesn't damage paint to really be that big a deal.
If you switch over to the DOT-5 fluid you WILL have to change everything made of rubber in your brake system and flush out your hard line thoroughly, as it is not compatible with DOT-3 or DOT-4. If you do that and decide to switch back, you will have to change out everything rubber again.
The only entity that has gone completely with DOT-5 brake fluid is the US military, due to its superior cold weather properties, but they are in the process of phasing it out.
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 10-30-2010, 11:57 AM
njsteve's Avatar
I removed mine and sent it to Bill today. Should be at his place on Monday. Still could use a spare, though.
As for brake fluid, on the old restored cars I use the silicone brake fluid because in cases like this, where some seepage starts that you don't notice til it's too late, I would have had to repaint the inner fender, and frame rail to repair the damage that regular brake fluid would have done to the area. I don't really notice any difference using the silcone fluid, the pedal had a nice firm, non-compressing feel to it, even with the seepage from the prop valve o-ring.
For modern cars where the braking system's maximum capability actually matters, (I used to run Castrol SRF in my viper race car years ago) yes, the best fluid with the highest boiling point was the way to go. That cars pedal felt like you were trying to compress a cinder block when applying full braking at speed.
Old 10-30-2010, 01:36 PM
MDSHARK81 MDSHARK81 is offline
I am restoring a 71 TA and need new proper porp valve as well, I have the aftermarket one and its completely different. does anyone have bills number/ address i'd like to have him redo my original one although its pretty rough, if someone has another spare it would be appreciated. let me know. thx
Old 10-30-2010, 02:27 PM
SO, Whats up with DOT #3 Synthetic fluid I see for sale??
Old 10-30-2010, 02:55 PM
njsteve's Avatar
You can pm Bill. He is 70RAIII on the forum. Great guy, he restores a bunch of different components.
Old 10-30-2010, 05:34 PM
johnsma22's Avatar
It's marketing hype. All DOT 3 and DOT4 brake fluids are synthetic. Always have been, though now it's a sales marking thing to point it out. DOT 3 brake fluids are mixtures of glycols and glycol ethers. DOT 4 contains borate esters in addition to what is contained in DOT 3. They are all composed of synthesized chemicals.
John
Old 10-30-2010, 06:26 PM
Thanks Johnsma22 !! The 3 and 4 are still different then Dot #5 , correct? not compatible for a" top off" ?
