Old 11-08-2010, 12:20 PM
Goatboyj Goatboyj is offline
Default horn not working & driving me crazy
Hi folks this one is making me crazy & I'm hoping someone here can help with the fix.When I tighten my steering wheel up I lose my horn. After checking with a meter I see that I lose the ground on the the center shaft that the steering wheel bolts to.(if i ground that i get the horn back)My question is what grounds the center shaft?The only thing I see in there is the bearing in the steering column switch which is getting a little sloppy I might add.Am I missing something? Just to mention this is a 66 gto A/T on the floor non tilt column.
Jay
Old 11-08-2010, 02:27 PM
Old Goat 67's Avatar
Isn't there supposed to be a strap across the rag joint?
Old 11-08-2010, 02:29 PM
67droptop's Avatar
67droptop 67droptop is offline
Yes!
Old 11-21-2010, 11:18 PM
Well today I put a ground strap on the rag joint & sure enough the horn is working again.
The strange thing is I have owned the car for 11 years & it never had a ground strap there & the horn worked fine. guess it's getting a little fussy in it old age.Just glad it's working again....Thanks all for the help.....
Jay
