Old 11-15-2010, 02:24 PM
68lemansman's Avatar
68lemansman 68lemansman is offline
Default storing away for the winter!
What would be helpful tips in storing my car away for the winter? Does it have to be a climate controlled garage also?
Old 11-15-2010, 04:19 PM
goatnut's Avatar
goatnut goatnut is offline
No you dont need a climate controlled garage but you do need it to be dry.
Heres what I do: 1- clean car inside and out wax etc.
2- fill tank and add stabile or other brand of fuel stabilizer. Make sure you run the engine to get the stabilizer through the whole system.
3- pump the tires up to 50 psi - keeps from flat spotting if not using jack stands. If using jack stands make sure they are under the suspension so as its not hanging.
4- remove battery to keep from freezing or connect a battery tender to it.
5- cover and forget till spring.
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
Old 11-15-2010, 04:50 PM
shineybike's Avatar
shineybike shineybike is offline
I do exactly what goatnut specified. Car is stored in an unheated barn from the end of October until the end of april and I live in Maine (long cold winter). Never had a problem.
1968 Lemans Convertible
Cameo Ivory, Red Interior, White Top
Old 11-15-2010, 05:17 PM
I feel a bit guilty;
All I do is part them and disconnect the batteries and I start the cars with AC once midwinter, cars are in nice dry heated garages though. Fresh oil in the spring.
The only problem I ever had with bad gas is from years rather than months of storage.
Old 11-17-2010, 05:05 AM
Aus Goat Aus Goat is offline
[QUOTE]What would be helpful tips in storing my car away for the winter? /QUOTE]
Send it to Australia its nicccceeee and warm here.
Time to put the top down and cruise..... Sorry guys
Old 11-17-2010, 02:14 PM
GregP GregP is offline
I also do the same as goatnut but I also added a "car jacket". It zips up like a sleeping bag for the car. Car goes in and comes out the same,no cobwebs, dust, mice, etc. Comes with reusable desiccant bags to absorb moisture. Also adds another layer of protection if you have other things in the garage (like children) that may bump into the car. Heres a link to one site that has them. http://www.autoanything.com/car-covers/69A1798A0A0.aspx.
PS: after re-reading this it sounds like I have a vested interest in them..I don't , just happy with the product after 6 years of use.
Old 11-17-2010, 04:25 PM
[QUOTE=Aus Goat;4155135]
Not fair would be nice to have year round warm weather.
Old 11-17-2010, 04:29 PM
andyg's Avatar
andyg andyg is offline
Send a message via AIM to andyg
I'm a little crude with my storage I guess. I drive it into the garage and leave it as is until next spring. I might throw the charger on the battery once a month for a few hours if the voltage reads low on a meter.
I like to keep it ready to go as I've been known to take it for a quick spin mid winter as long as there is no salt or snow on the roads. People give some interesting looks when someone is driving a 40 year old car with the top down in mid January...
1969 GTO. Full rotisserie restoration "completed" in 2014. 5.3L "LM7", TKO600, 3.55's out back. Big cam coming soon.
Old 11-18-2010, 01:41 AM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Yea what he said, going for a cruise over xmas Aus Goat, I'll have to put the a/c on....LOL
Seriously thou, it must suck having to pack away your pride and joy for 6 months a year.
Old 11-18-2010, 02:54 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Anyone ever squirt in motor oil through the spark plug holes to keep the piston top and rings oiled? A few of the old timers told me to do this and had been for years, first start up had a bit of oil for a minute but that's it.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 11-18-2010, 07:36 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
Me and my Goat live in upstate S.C. Don't have really cold winters. Low usually in the 40's, although we do have cold snaps into the 20's sometimes. Daytime high usually in mid 60's. No salt on the roads that I am aware of,although the Highway Dept will salt the bridges sometimes. I still drive mine in the winter and stay away from bridges, just not as much as summer. My son and his family live in the Florida panhandle and I have made a trip down there in my Goat, no problems at all. Although my wife was following in her car because she stays with him longer than I do. I dearly love my grandkids, but about 4 or 5 days in same house is all I can enjoy.
Old 11-18-2010, 09:34 PM
goatnut's Avatar
That would be for long term storage not needed for 6 mths or less. Although I do prime my engines before starting in the spring.
69 GTO Judge
Old 11-18-2010, 10:01 PM
goatless's Avatar
goatless goatless is offline
I'm with Andy- I just drive 'em into the garage and leave them until I need to move them again. I'll often move the cars around in the winter to get them in better locations for working on, so they usually don't sit for more than a month or so. I will keep driving them as long as the roads are clean without sand and salt.
1966 GTO
Old 11-18-2010, 10:48 PM
65WJ's Avatar
65WJ 65WJ is offline
all the above and one more. I do check my anti feeze with a hydrometer to make sure its ok.
Battery tenders are great. Never had a problem with mine.
christmas eve a few years ago Mom and I went for a long ride. Met and talked with a couple out driving thier 57 t-bird. Just looking at christmas lights. Picked up some BBQ ohh that was a great night. rip mom.
patrick
