Old 11-19-2010, 01:41 AM
codyyy's Avatar
codyyy codyyy is offline
Default How to fix this problem?
My '68 has a decent-sized hole in the lower corner of the firewall on the passenger side, to the left of the first body mount there. It goes through about 3 sides of metal it looks like. I'll get a pic of it in the morning if anyone needs to see it, but do they make some sort of patch for that? Or do I have to start fitting metal in place? Thanks.
Old 11-19-2010, 02:09 PM
codyyy's Avatar
Pics:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 11-19-2010, 03:42 PM
69Customs's Avatar
69Customs 69Customs is offline
They do have a patch panel for that. It was covered in this forum before but not sure where it is. Fender covers that area so looks aren't that important. I had hole about size of a quarter, just cleaned and prepped good so it wouldn't rustany more and covered when installed fender. Figure it would be beter for getting any rain water out the bigger the opening. factory drain holes weren't that big to begin with.
Old 11-19-2010, 04:05 PM
codyyy's Avatar
This is probably the worst spot on the whole car. I tried looking in my PY catalog but I don't think I saw anything for that particular spot.
Old 11-19-2010, 04:30 PM
69Customs's Avatar
Ok it was in a forum titled "69 GTO cowl panel". Not sure how to link it but if you put that into the search it should come up with it.
Also parts place sells it as 69 GTO firewall outer cowl panels LH or RH
Old 11-19-2010, 04:53 PM
codyyy's Avatar
I'll go check it out thanks. Could I patch this with the frame on?
Old 11-19-2010, 05:10 PM
69Customs's Avatar
I would think so. If the rusty area doesn't run under where the frame bolts are. But then I never used the patches. As a matter of fact I didn't even know they existed until someone on this forum spoke up.
Good luck with your repair
Old 11-19-2010, 05:16 PM
antique69lemans antique69lemans is offline
That part is referred to as a cowl shoulder. Look at the pic and you will see it comes as two pieces. You cut the outer cowl off, then the inner portion in the blower motor and kick panel/door hinge area. Afterwards you weld the outer skin on. This is listed as a chevelle part, but surely all a-bodies would work.
http://cgi.ebay.com/ebaymotors/68-19...Q5fAccessories
Old 11-19-2010, 07:28 PM
PontGuy's Avatar
PontGuy PontGuy is offline
My drivers side had holes at the bottom but looked a lot better than yours. I spent a ton of time making and welding in a fairly complex patch for it. It came out fine and the fender covers the repair anyway. But I definitely would spend the $120 on the patch panel if I had to do it over again.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 11-19-2010, 08:34 PM
codyyy's Avatar
I kinda would rather like to have a smaller patch, I'll look around and see if anyone has a cut out piece from an original.
Old 11-20-2010, 02:09 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
I repaired both sides of my 69 from a doner car turned out real good. I know you dont see it when the fender is on but I still DO NOT want to see the repair with the fender off. Just anal I guess!
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 11-20-2010, 10:21 AM
69Customs's Avatar
I have to agree with you codyyy. The less metal you patch in the better, but you can always cut out what you need in the repair panel and throw the rest away or cut it up for other patches.
