I mounted some stickier-than-usual tires and am racing at the new Chuckwalla Raceway between Blythe, CA and the Nevada border. 17 turns, 2.7 miles. The same motor that - on Dunlop 204s - at Sears Point and Laguna Seca is fine, on these stickier Hoosiers is filling the valve covers with oil and today actually blew the rubber filler plug out. I have a Canton trapdoor pan, crank scraper, baffle, Accusump, external filter, oil cooler, restricted lifters and pushrods, etc. Pump pickup is 3/8" off the floor. 20-50 Kendall Titanium. 50-60#s at 4000 RPM @ 220* oil, 220* water.
I know there's a thread somewhere about draining the heads into the pan. Can someone point me at it? Was there ever a '59-'62 drysump setup I can copy? Have to stay period-correct. Thanks. |
what heads? wht rpm most of time? and 60 psi pump may still pushes alot more oil than standard hv. may need t0 work on oil return through the head passages.
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
any chance your accusump (2 quart?) is coming on and dumping its load into the system? does the oil pan have the side pockets or is it a trapdoor style with straight down config?
#13 heads, 5000RPM average. I'm sure the Accusump is kicking in, as I'm seeing the 20 PSI warning light in the sweepers. Pan is a Canton kit on a stock pan with one kickout and 5 doors.
seems like you really do need to get return lines down to the pan off the heads. if the accusump dumps its load you've got that much extra oil in the system for a few moments and it sounds like the oil pump is getting it up top faster than it can come back down--add in the extra and the top end is overloaded. the returns would also likely help prevent it from kicking in as often. In regards to a period-correct dry sump, does it have to be pontiac specific? Plenty of F1-F2-sports racers of that era ran dry sumps.
Might think of some restricted pushrods, although the oil on the top end helps cool the valve springs for those extended runs compared to a drag car.
When I started autocrossing with slicks I started slinging oil out the TH350 vent and had to extended it. Slicks are fun but throw stuff around with the added G forces.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Are you sure its just not crank case pressure? Your oiling system seems looks pretty good and you will start putting in oil in the heads but I dont think I have ever seen/heard of putting in enough to push out a valve cover plug.
Johnny 1980 455 TA Autocross/Hillclimb Powered by SD Performance http://youtube.com/watch?v=Xc5rpSGwXlM Suspension by www.pro-touringf-body.com |
We glued the filler cap into the valve cover and added 2 extra quarts. Oil pressure is now stable and no leaks upstairs, but the extra oil is pushing out the front seal at speed. Not enough to quit running, but enough to make a mess.
I don't think the rings have given it up yet, as there's nothing in the vented oil puke tank which is connected to each valve cover with a 3/4" hose. When the rings went last time there was a lot of oil/vapor in the puke tank. For a while I was draining it back into the engine from the bottom of the puke tank into the PVC hole in the valley pan. After a rebuild, the puke tank was never wet. |
