Block filling (dumb) question
Do you pour the filler through the water holes in the head surface of the block, or through the water pump holes in the front? Also, do you tilt the block back slightly so it runs to the back? First time for me, and I bought the P-Dude's filler
Thanks, Kenny
Kenny Cincinnati, Oh 1971 Ventura II 400 .060 Eagle Rods |
Most folks pour thru and fill up to bottom of the side freeze plugs unless you need to fill higher then its thru the deck holes, and eitheir way that cylinder bank needs to be level in both the horizontail and verticle plane.
Most engine stands are angled to the rear in the horizontial plane so you need to shim up the two rear wheels.
Will be completely filling the block, at least up to the bottom of the water pump holes
Steve, when you said level both vertically and horizontally, did you mean have the deck surface facing up, and leveling that surface? Doing each side one at a time?
I use a cardboard-gutter to transfer the bottle-pour into the Front&Side&Rear Holes. Then I use a long stainless rod with a small washer screwed onto the end to push the cement along the Valley channel. The Valley Channel is the tough one to see how it's going, so use a bright LED lamp stuck in your ballcap (Miner's helmet) to see in there. NEVER poured thru the deck. ================================================== ============== Someone give the right advice for installing LEAK-FREE Freeze plugs after this; he's gonna need to know. |
I saw a thread on that subject a few days back, on the leak free freeze plugs
So do you not completely fill the block if your not running alcohol? I still don't think I got my question answered after the first couple of responses. If the block is setting horizontally, do you just fill it to the bottom of the water pump holes? Car is na and not street driven. After the earlier responses, I think I just got more confused.
Not a dumb question at all, you got great answers, i personally filled mine thru the soft plugs on the side of the block until it was even with the bottom of the water pump outlet holes. I am drilling my deck for extra water passages and filling one up. New expwerience for me, Hope it works as good as they say, been following the ideas here in the forums.
Do one bank at a time, until is sets, then do the other bank.
Set the block up on the stand so the deck is level front to back and side to side. Pour in through the water pump hole at the front of the block. The warmer it is the easier the job is...in other words, you don't want to be pouring this stuff on a 35 degree day with a cold block. Dude's filler flows like maple syrup so as long as the block is clean (and it should be hot tanked prior to doing this) it should fill evenly front to back and side to side. If you want to get anal-retentive about it, you can rent one of those industrial vibrators (I think they use them in the concrete business) and hold it against the side of the block immediately after the pour to ensure the pour is even and free of air bubbles, but Dude's stuff pours so well it isn't really needed. You can bore the block prior to filling, but leave all final hone machining on the cylinders for AFTER the fill. If you really want a full fill, place some duct tape across the bottom half of the water pump hole and fill to the top of the tape. After it sets/hardens, you can use a die grinder to cut some of it away from the hole, making it look like a "cascade" or "waterfall"...this way if using a water pump the hole is not as restrictive. I ran my 455 block like this in the Discomobile on gas with nitrous. This is obviously a race only fill. On the street I have ran a 455 block that was filled to within 1/2" of the bottom of the water pump hole, on gas, driving it daily, with no adverse effects.
There is RUMOR that the oil temp goes higher (40F or 50F above coolant temp)for half-filled blocks on the street, that do sustained highway driving.
Oil-heating mechanism: is the CYL oil has the heat and is scraped-down, yet only gets brief (nearly zero) contact time on the Block-side, then going into the sump. Showing PMD had water-jacket down there to transfer that heat out to coolant. I would like to hear about that, in preference to arguing it down to oil is closer to Coolant level (which I doubt). Have a nice day. HIS |
I was told the same thing, Mark...but it was more about the filler covering the area adjacent to the oil galley in the block as the reason why oil temps would be higher. I ran a remote filter with a large capacity filter and although I don't know what the oil temp was, I never had any ill effects with the engine daily driving it for 18 months.
I used Dude's filler and it flows very nicely around the cylinders and vibrating the block isn't necessary. FYI, one tub just barely made it to the bottom of the lowest freeze plug hole so if you want to fill higher, get more than one tub. You need to make one pour per side to do it right, let it sit a day or so and then do the other side. If you were to fill completely I would tape off the holes on the deck and pour through the water pump holes with freeze plugs installed.
" Darksiders Rule "
Make sure the deck of the bank you are filling is level, both forwards and side to side. Agood fill will even out. I pour thru the deck and water pump holes. Before mixing the epoxy, I block off all cylinders, and form little"funnels" in each water hole/deck hole I use.
This way it's a fast easy pour without spill mistakes form trying to move a funnel or other mishaps that can happen. Prepare prepare prepare, and the job will go smooth. I also only mix half of the epoxy (I do not use pull away from the cylinder walls concrete/grouts based junk that have different heat/cooling rates than the block) for the first bank so both will have the same amount when done. |
I use a tranny funnel and fill from the back and front. I stick the funnel in a good ways so the inside middle gets fill. Filling that high it should flow around to the sides.
Race I install the center freeze plug and fill to the bottom of the outside freeze plugs. If you gonna run 14-1 and make a lot of hp. then I will tape half way up the front WP holes and fill within about and 1" of the top. If your worried about oil temps. Install an oil cooler like the BBC and 1 tons use for towing. |
I just used a small funnel and filled it through the leveled deck holes to the bottom of the water pump hole. It will take almost two tubs of Dude's filler to get there. You can wait till the one side sets up and do the other side in one afternoon. I only mixed part of it at a time. Dude's transmission funnel sounds like a good idea. It takes a while to fill it through the deck holes with a small funnel.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Someone needs to make a "sticky" with all these detailed Pontiac (some could apply to other makes) engine building mod's. I like to read all this stuff, I'm not a novice, nor am I a seasoned expert that does this work every day, Thank You Kenny for asking this question, good info.
Leave cam selection off the sticky though, please ...LOL
