Old 01-01-2011, 06:23 PM
OB1KUBOTA's Avatar
OB1KUBOTA OB1KUBOTA is offline
Default Need help removing 68 kick panels
I cant seem to remove my kick panels on my 68 Lemans Rag top- Non ac. car
I used a small screw driver and reached in through the grill to lift up to disconnect the
fresh air vent cable . I did not see any screws. I tried prying on the grill to see if it comes off but no luck .
Old 01-01-2011, 08:53 PM
Cammer-6 Cammer-6 is offline
the dumdum sealer used has glued it in place.
Pry gently and it will come
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-02-2011, 12:37 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
There are screws behind the grill and it will come off. The door and cable will come off with the panel as a unit. There is sealer as Cammer mentioned on the backside.
Leo
