Old 01-14-2011, 04:34 PM
DQMoBiLe62 DQMoBiLe62 is offline
Default Need Some Shoes !!!!
Hi All.... I can't find anywhere online to get Front & Rear Break Shoes for my 62 Tempest 4cyl.. Anyone know of a place ???
Thanks!
Old 01-14-2011, 09:53 PM
mechanickeith's Avatar
Not that I can find. Many years ago, I took all the shoes off of all my cars plus all the extras I had laying around & turnd them into the local heavy duty brake repair shop. I had all of the relined & had them bonded, not riveted. I found on my cars, when the shoes wear out, the rivets destroy the drum. When a bonded shoe wears down till it is metal to metal, you know it instantly. When it wears down to the rivets, you dont hear it till the drum is toast. Call around to any local "industrial" brake shop, they should be able to fix you up. Of all the sets I had done, only have one set left. Need to turn them all in again!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 01-14-2011, 10:36 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default 62 brakes
Try calling Parts American in Minneapolis and Duluth Minnesota....1-888-399-7278. They rebuild all kinds of brake shoes. Currently they have a deal on ebay selling all eight relined shoes for around $50.00. Don't know if they need cores.
Old 01-15-2011, 01:04 AM
racer_x's Avatar
racer_x racer_x is offline
I don't know if they are the same, but I ordered shoes for my 63 from Kanter. 60 bucks, and 15 bucks for a spring kit.
Old 01-15-2011, 10:47 AM
azkeebler's Avatar
azkeebler azkeebler is offline
Default Corvair shoes.
Ironically, I have been working on this issue. I have too been taking my shoes in to have new material bonded , but is costly.
I have purchased corvair shoes from the local automotive store (O'reilly's Auto)relatively cheaper ~$30/set, and noticed the even though they are the same size as tempest, the link pin recess is deeper then the tempest shoe. However, you can purchase the proper hardware new form your auto parts store along with the starwheel adjuster (H12 universal hardware kit)as it needs the wider slot for the thicker metal of the the shoes.
The tempest cylinder links (pins) are only 1 5/8 inch long and the corvair are 2 inch. I believe the shoe set I'm using is part#189, currently priced at $17.99, 2" cylinder link H1414-2.
Now....if we can only get those dang drums reproduced at a reasonable price. Any luck on the ranger drum interchange?
2-1962 Lemans convertibles 4cyl, auto
1962 Tempest safari wagon (running project)
1972 455 Formula (tribute)
1962 Skylark convertible 215 4-barrel , auto
2009 G8 Sport red metallic, Onyx leather
Whatever else that make my way into the driveway
Old 01-15-2011, 02:25 PM
SD421's Avatar
SD421 SD421 is offline
+1 I used Kanter for all of my braking & suspension needs when I still had my 1962 Pontiac LeMans Convertible. They dont carry brake shoes but everything else. http://www.kanter.com///index.aspx?T...t=0&MSb=0&Prc=
I think I bought the shoes off of eBay if I remember right. This auction is up right now for 61-63 Shoes.
http://cgi.ebay.com/ebaymotors/PONTI...Q5fAccessories
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 01-15-2011, 09:33 PM
67SS&99SS 67SS&99SS is offline
Bought ours from Kanter too.
Andy
1962 Tempest Lemans 4 cyl auto
1967 Camaro
1969 C/10
1969 D300
1972 K/5
1974 'Cuda
2005 2500HD Duramax
Old 01-15-2011, 10:17 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
I was able to find shoes from ebay n.o.s from a guy name Joe Wheat. Locally here, Hagens Auto parts I think sells shoes also. I had them rebuild my master and wheel cylinders. I recommend them, thou it's a small operation, so it may take some time to get parts.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 01-16-2011, 11:21 PM
beemergary's Avatar
Default shoes
Try Northwest Auto Supply in Michigan. I have the fronts that I took off to do a disc brake conversion. Seems like they were in good shape. PM if interested.
Old 01-20-2011, 11:40 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Praise dyno brake in Texas can do them. $100 an axle.
All the nostalgia drag racers seem to have good success with their linings.
