Old 01-14-2011, 06:05 PM
Peje Peje is offline
Default Rear drive shaft bearing
Ratech Bearings,good quality? Havenīt heard about the name before.My old bearings are Federal Mogul RW507CR(only brand in Sweden).
Old 01-14-2011, 07:00 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Are you referring to the pinion bearings? Ratech is a popular brand of rebuild kits for ring and pinion installations and are of good quality. They dont make the bearings actually.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 01-14-2011, 07:32 PM
Sorry,referring to the rear axle shaft bearings,Ratech 9108.Sold by Summit.Found several manufacturers such as: Timken,National,SKF(originally from my country) but never heard of RATECH.
10 bolt 8.2 3.55 axle
Old 01-19-2011, 02:23 AM
PaulatFast PaulatFast is offline
Once again... as Pontiac Larry stated, RaTech is a company that sells kits for things like setting up rearends or replacing your axle bearings. If you buy a Ratech kit, it will not contain RaTech bearings. The bearings will be Timken, national or SKF.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 01-19-2011, 02:42 AM
Aha! Okey,thanks very much for info.
