Old 01-15-2011, 01:01 PM
Big Banger's Avatar
Big Banger Big Banger is offline
Default 1965 GTO 2 door post #'s match
PHS documented, WT code 389, HD 3 speed manual, 3:23 posi, Teal Turquoise with dark turquoise interior, tinted glass, am radio, spinner caps. No power steering/brakes or console.
Missing: am radio, horn ring, original steel wheels, fan.
It has an aftermarket shifter and Edelbrock carb on it, the original shifter and original carb are included.
The car has been stored and not run since 1996, engine turns over, brakes work.
Needs rust repair: lower rear quarters, small patch in each front fender, trunk pan, main floor needs at least patches maybe replacement, both boxed sections of the frame behind the front wheel and ahead of the rear wheel on the drivers side need a small patch. I would expect at the least pinholes in the front and rear window channels. The rear tail panel above the bumper/below the trunk lid is pushed in a little. The car is quite straight, unmolested and original.
Located in Surrey, B.C. about 15 miles north of Blaine, Wa. The car is not registered here, I have a clear Illinois title for it. I believe the buyer has to be present to import it back into the USA.
$6800 Canadian Dollars, PM if interested.
Old 01-24-2011, 03:42 PM
Big Banger's Avatar
Sold it!, Sold it!, Sold it!.
