On my 79 Olds 403 powered Trans am the preivous owner put in after market oil and temp gauges and hacked up the wiring harness. My question is on the oil pressure switch there is a small tube which runs thru the fire wall and connects to the gauge. Does the original switch only use a electric wire tied into the harness plug that plugs into the gauge cluster, or does this tube coming out of the switch get connected somewhere?
Thanks for any help my manual doesn't address this.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
Thats a mechanical gauge. The original is electric. You need install an electric sending unit and the wire runs off the engine harness to it
How does the temp plug in, is it on the engine harness also?
Thanks for the reply. I'm guessing that you can only get the switch thru performance years / year one type operations, or would autozone carry it?
The oil sender uses a single wire that goes to the firewall connector block, thru to the cabin harness connector, and then to the cluster printed circuit (it's shown as "31" on the schematics). Same deal for the temp sender, it's shown as "35". I got my sender from PY. I don't think the local stores had it, but you can try. RockAuto online is a good source. |
Does anyone happen to have a picture of the harness set up they can send. I would like to put mine back original if I can.
Thanks.
oil pressure wire is blue, temp sender wire is green.
Don't know about now, but 10ish years ago the oil sender was still stocked in chain parts stores.
I did find a oil sensor for the gauge at Autozone. I have a 45degree stem from a 68 Olds 400 motor don't know if it is the same one Pontiac used though. Does anyone have a picture of the sender on their 403 powered Trans am they can post?
Thanks.
