Old 02-06-2011, 07:11 PM
6ragtop8's Avatar
6ragtop8 6ragtop8 is offline
Default 1968 PHS
Can anyone tell me what columns 74-80 are for on the billing history sheet? The larger sheet that show options that I received from PHS stops at 73. I have a number 2 in column 74, and cant find what that references. I will appreciate any help decoding my PHS. Thanks
Old 02-06-2011, 11:13 PM
68pongto's Avatar
68pongto 68pongto is offline
I think Jim Mattison told me once that they to do with stuff like shoulder belts. I believe shoulder belts were not Federally mandated until 69. So some 68's may not have had factory installed shoulder belts. I have seen codes 731, 742, and 754. Scott
Old 02-07-2011, 12:02 AM
MoonShiner's Avatar
MoonShiner MoonShiner is offline
I have 742 on my PHS also. Don't know what it means. I have 754 which is for shoulder belts as said above.
Old 02-07-2011, 12:38 AM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
731 - air cleaner, dual stage
I have several PHS with 742 - ??
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 02-07-2011, 08:48 AM
6ragtop8's Avatar
Default More questions?
I have another question on column 34 (engine) there is a 5. On the option order form 5 is not listed, it has numbers 1-4 then 6 and 8? I also see 49 4 what is that?
Old 02-07-2011, 09:09 AM
The Boss's Avatar
The Boss The Boss is offline
345 is not on the options list because it was standard equipment - the 400/4bbl engine was standard for the 68 GTO.
494 is Rally Stripes
754 is Front Shoulder Belts
And go racin' in the street.
Old 02-07-2011, 09:28 AM
6ragtop8's Avatar
Thanks to everyone for the help! I don't think I have ever seen rally stripes on a GTO any one have a picture?
Old 02-07-2011, 01:44 PM
It's just a double pinstripe that runs from front to rear above the lower style line.
Someone probably has a better photo but my first GTO that I bought in '82 had the stripes. You can just barely make them out in these photos. Look right below the GTO shield on the fender and right above the rocker extension behind the wheel opening on the quarter. Second pic, right ahead of the wheel opening.
Old 02-07-2011, 03:17 PM
johnta1 johnta1 is online now
I take it the billing sheet '74' isn't the same as '74' on the buildsheet?
Old 02-07-2011, 05:12 PM
Keith Seymore's Avatar
I would think it would be (in prior years they corresponded).
K
'63 LeMans Convertible
'63 Grand Prix
Old 02-07-2011, 07:13 PM
I initially thought it might be for tires or spare tire/wheel.
Looking at Eric's blank Build Sheets it hard to say.
I don't have many 68 sheets that are legible, I have one for 69 which doesn't match Eric's 69 sheet though.
Evidently different plants had different styles.
(Mine is an Arlington car)
A lot of my 69 sheets show NG-5 in 74.
ID:	233879   Click image for larger version
ID:	233880   Click image for larger version
Old 02-07-2011, 07:15 PM
Here is the info sheet:
Old 02-07-2011, 07:51 PM
68gtoMN's Avatar
I'll put up one of my 68's later
'70 LeMans Sport
Facebook Event
Old 02-07-2011, 08:19 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Check post #5 here on 742 code http://forums.maxperformanceinc.com/...ght=order+form
Leo
Old 02-07-2011, 10:02 PM
6ragtop8's Avatar
Some other questions have come up...My GTO has power steering but it is not checked on the billing history? Also about 10 years ago I had the gas tank out of the car if I remember right it had 5/16" fuel lines. Is that correct for an original 4bbl. 400?
Old 02-08-2011, 08:39 AM
The Boss's Avatar
71 & 72 are tires John.
For example a P in 71 and a C in 72 would be G70 Wide Oval Red Line Tires.
Old 02-08-2011, 10:14 AM
I saw that, that's why I thought maybe it was for a spare tire or wheel since it was below the 71/72.
Most didn't show anything in 74 so figured it would be for standard spare/wheel.
Some of the 70 sheets (which looked like the 68/69 sheets) had the NG-5 or 4 digit numbers.
From that other link, it could just be an internal use thing.
But why would it be down there?
Possibly it's for how the spare tire mount in the trunk was welded on?
Or?
Old 02-08-2011, 12:46 PM
6ragtop8's Avatar
How about dealer codes anyone know how to decode that?
Old 02-08-2011, 12:48 PM
The Boss's Avatar
http://www.wallaceracing.com/dealer-zone-codes.htm
Old 02-08-2011, 03:03 PM
6ragtop8's Avatar
Zone 09 Dealer 337 not listed on Wallace site? Anyone know that dealer code?
