Old 02-11-2011, 10:37 AM
MotorHead_811 MotorHead_811 is offline
Default Test question on my automotive test
Yesterday I took my test in basic engine and one of the questions was true/false and the question was Torque always increases with engine RPM and I put true and it was wrong. I know torque increases to a certain point than drops off and even said that to the teacher and he said your sort of right. So I just want to know what everyone else opinion is?
78 firebird 400/t400
Old 02-11-2011, 10:53 AM
quicksilver97ta's Avatar
Torque is a twisting force measured in foot/pounds. Its a measured at any given rpm or no rpm. When you pull on a torque wrench you are applying torque. Are you turning the bolt or just pulling on it? It doesn't matter. It's going to be different from engine to engine depending on the type of engine and combo. Search out some dyno graphs to get an idea, you can see how much it can vary. Most car people desire a broad, flat, torque pattern.
Old 02-11-2011, 11:02 AM
69goatboy's Avatar
69goatboy 69goatboy is offline
If the question was worded as you wrote above, then your answer was indeed incorrect.
Since you knew it drops off at a certain point (and hence strikes down the 'always' portion of the question), then you should have answered false.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 02-11-2011, 11:10 AM
Here is another one for you my teacher says if he was going to rebuild a performance engine to go into a muscle car he said he would use a flat tappet cam and not a roller cam.
Old 02-11-2011, 11:19 AM
Dr. Drivability Dr. Drivability is offline
Sounds like one of those misleading ASE test questions...
-Jeff
http://www.cardomain.com/ride/3323983
Old 02-11-2011, 11:25 AM
69goatboy's Avatar
Sounds like it's been awhile since he's built one and isn't aware of what is out there now.
Either that or he's stubborn old school.
Old 02-11-2011, 11:31 AM
He was even saying how rollers have a few more benefits but would still go flat tappet some of the stuff he says I get a good laugh out of and let it go in one ear and out the other.
Old 02-11-2011, 12:11 PM
stimpy stimpy is offline
there right, you are incorrect . as for the roller cam statement , does he own a flathead too ?
Old 02-11-2011, 01:04 PM
sleepy's Avatar
sleepy sleepy is offline
This was more of a comprehension question. The word "always"is the key. Plus your answer would only be right if it said to a point then drops off.
example: the cruising rpm for a cat diesel is about 1600 the peak torque rpm is about 1200. peak hp is around 1750.
It was a trick question. To see if you were paying attention.
Why is he not suspended?
Old 02-11-2011, 01:57 PM
Half-Inch Stud's Avatar
TQ = HP at 5250 RPM
Old 02-11-2011, 02:01 PM
trailwing's Avatar
trailwing trailwing is offline
Torque isn't a twisting "force"; it's the product of force and distance. The units are ft-lbs.
Old 02-11-2011, 02:24 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Torque, as it relates to engine design
http://www.epi-eng.com/piston_engine...and_torque.htm
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 02-11-2011, 05:52 PM
SRR's Avatar
SRR SRR is offline
torque 1 (tôrk)
n.
1. The moment of a force; the measure of a force's tendency to produce torsion and rotation about an axis, equal to the vector product of the radius vector from the axis of rotation to the point of application of the force and the force vector.
2. A turning or twisting force.
http://www.thefreedictionary.com/torque
― Calvin Coolidge
Old 02-11-2011, 07:38 PM
trailwing's Avatar
Torque is not a "force" within the context of classical Newtonian physics.
Old 02-11-2011, 08:29 PM
screamingchief's Avatar
screamingchief screamingchief is offline
HP & TRQ will always have a peak in a 4 cycle internal combustion engine,so that means they also always have an uphill and downhill slope as well.
If they did'nt,all the dyno graphs you see would all just be an uphill line.
Now granted the slopes can be really steep & peaky,or slow gradual slopes with a barely discernible peak,but the slopes are there none-the-less.
And even a perfectly flat torque curve would'nt "increase" with RPM,it would just remain the same (ie: a constant).
This all will surely just lead to a huge debate that amounts to a semantics battle royale,but suffice it to say,torque does not always increase with RPM.
FWIW
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 02-11-2011, 10:08 PM
SRR's Avatar
SRR SRR is offline
Default Expanded definition
Originally Posted by SRR View Post
torque 1 (tôrk)
n.
3, One of the Monkees
4, Look at my sig pic.
Dear God, Please don't let motordaddy see this thread.
― Calvin Coolidge
Old 02-12-2011, 01:21 AM
trailwing's Avatar
I'm not sure what you mean by this...
Old 02-12-2011, 03:23 AM
Pray that it stays that way,consider yourself lucky that you dont know.
The problem with that question is the very "open ended" nature of the question,if one was looking at only a small "snapshot" of a dyno graph in a very targeted RPM range,then yeah it may appear that trq. climbs consistently with the RPM increase,but that would be very misleading as sooner or later the trq. is going to start to "drop off" as the RPM continues to climb past it's given "peak".
IE: it's a trick question.
Bret P.
Old 02-12-2011, 09:16 AM
Keith Seymore's Avatar
Bret P.
Agree.
True/False questions with the word "always" in them are "always' false.
One should never use absolutes like "always" or "never"...
(...usually...)
'63 LeMans Convertible
'63 Grand Prix
Old 02-12-2011, 09:44 AM
Cool
Originally Posted by Half-Inch Stud View Post
TQ = HP at 5250 RPM
Hey, I bet this answer was the point of the Test Question.
BTW, my Musclecar has a fresh flat-HYD cam in it.
