Old 02-19-2011, 09:14 AM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
Default Balancing a Pro Star??
So, I went to Sears Autocenter because I HAD to have a tire yesterday to see if it fit my car, they had the tire in stock and the lowest price-or so I thought. Online price $95, store 121.59, what? I had driven a ways so I just bought the tire and had it mounted. I asked for chrome stem and stick on weights, no problem so far. Kid comes out 20 minutes later and says the tire wont balance unless he puts hammer on weights in the inside and outside. I tell him no, and recomment stick on weights again, he says OK. 20 more minutes pass he comes out and says he cant balance the wheel because of the "floating" center in the pro star wheel, says it moves and throws the machine off. My first clue should have been a 30 bay shop EMPTY at 4:30 and the oldest person there was about 21. SOOO is he right? where to get these tires balanced. I had some done years ago and it was not a problem, what should I do?
Old 02-19-2011, 11:07 AM
n20ta2's Avatar
n20ta2 n20ta2 is offline
bring it somewhere else,the floating center is held tight once the cone is tightened against the wheel.I usually bring the plastic caps that come with the wheel to help the tech center the hub in the wheel.That being said they are hard to balance perfectly thats why I went to a one piece billet wheel.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 02-19-2011, 12:15 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
The shop that does mine can set up his machine so that he can put the weights right up high just below the center section. I have no weights on the outside. I use the stainless bolt in valve stems
Old 02-21-2011, 09:13 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I had the same problem with mine. Center was wobbling when spun up, causing the balance to change. We now have a stud balancer, uses stud holes to mount rather than center. I did mine myself.
64 Lemans hardtop
4spd, buckets
