More help running solid rollers on a hyd roller cam...
If I have a hyd roller cam specs: .555-.555 @.050 .246-.254 308-316 lsa 112
Is this a mild enough cam to try running a tight lash sold roller setup? Also, if you run solid lifters does it change the spring requirements? This cam comes with dual springs with a #438 rate. Help? JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
