I'm trying to figure out where this screw came from... I found it in the center console when I was ripping apart my car.. It measures 3/4' to the bottom of the hex head screw and has a little O on the top of the screw... Heres a pix:
Looks to be the screw that fastens the bottom mounting ears of the fan shroud.
There are two that thread into the "speed nuts" mounted on the lower core support.
Home of WFO Hyperformance Shaker induction. |
Picture is a bit fuzzy,but looks like coarse thread which I believe also fastens the top of fan shroud to rad support. (maybe a bit long?)
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
if it is about a # 10 size it looks like a screw from the under dash a/c vents or the cover plate onder driver side dash head should be an 8mm If i remember correctly
Ok, I'm posting another pix from the digital camera and its not that much better than the first.. It looks to be a 5/16" hex head if that helps.. For some reason I'm thinking its either the screws that hold the center console to the floor of the car or screws that hold the back plate on the center console.. One of the screws has some surface rust on the tip of the screw, no where else, but my car was open to the elements so that might not help..
OK,that style of screw with a 5/16 hex head is used in MANY dash locations.
Also holds front console mounts to dash below ashtray.
That could def be it!! I had pretty much everything labeled in baggies but ended up finding these on the floor so I wasn't sure.. Thanks for the help!!
