Old 02-22-2011, 01:31 AM
SergeF SergeF is offline
Default Dynoed my 461. Thanks to PPR, KRE, Harry K
Finally got some numbers. 67 .060 over 400 block, PPR forged 4.21 rotating assemblly. Out of the box KRE High Ports, KRE portmatched North Wind Intake. Comp cam roller to KRE specs.
Tryed 2 carbs, HP1000 by Shaker455 and out of the box 1050 Dominator. Th350, TCI 10" converter, 4.10 gears.
Harry K took time to tune it. All runs made on 91 octane pump gas. Tryed race gas and no difference. Rev limiter was set at 6400 rpm. There is more in it. We will get 500hp to the wheels on pump gas but for now I am happy with it. This combo has better driveability compare to my old e-headed motor.
Old 02-22-2011, 07:49 AM
rad400 rad400 is offline
Sweet Motor SergeF. Have fun with that motor in your car.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 02-22-2011, 09:27 AM
73 TRANSAM 73 TRANSAM is offline
Default dyno
Did the 1050 dominator make a difference on your combo. It sure woke up my 467 pump gas combo.
Old 02-22-2011, 10:25 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Sergf, My e-headed motor put out about the same HP as yours but with a Victor intake. When I replaced the Victor with a NorthWind, As you have, I lost 15 HP but gained about 12 lbs. torque in the mid range. On the street the NorthWind drives better but on the track the Victor will run about 1 1/2tenths faster. Both Manifoldes were port matched to the heads. I have a chassis dyno and trust me when I say that there are very few street cars that push 470 HP and higher. Nice motor. What are the cam specs?
Steve
Old 02-22-2011, 11:38 AM
wheelspin's Avatar
Thumbs up Great result......
Nice selection of parts, Serge . Which car is it going into ? A bunch of the old Pontiac Drag Days crowd is going to a Fontana track rental on March 4. You & Harry should bring it out and run it .
Les Iden
Old 02-22-2011, 06:59 PM
cutrone's Avatar
cutrone cutrone is offline
Whatever car that motor goes in , it will be a rippin' mother.....
and a BLAST to drive !
69 Grand Prix 428 H.O. loaded "J"
11.51 @ 116
Old 02-22-2011, 07:49 PM
shaker455's Avatar
shaker455 shaker455 is offline
Very respectful numbers for the 4150 850cfm unit I built 6 years ago for an entirely different combo as compared to a 4500 1050 Dominator.
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 02-22-2011, 08:26 PM
LSRfbird's Avatar
LSRfbird LSRfbird is offline
Just curious, cam specs?
Low performance vehicles are for low performance minds.
Old 02-22-2011, 08:33 PM
440GP69's Avatar
440GP69 440GP69 is offline
Very Respectable, thats about 640-650hp at the flex plate and 610-620tq should be a blast to drive!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 02-22-2011, 09:31 PM
1qikta's Avatar
1qikta 1qikta is offline
What did those high ports flow? Seems like they should pull to or peak at 64 or 65.
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 02-22-2011, 11:03 PM
Dyno results with a dominator are in blue graph. Engine is in 72 Ventura. Cam is 260 270 at .050 and .609 lift with 1.5 rockers. Thanks.
ID:	235614   Click image for larger version
Old 02-23-2011, 06:32 AM
shaker455's Avatar
I just built & tuned one of my Dominators on a customers combo that is simmilar to Serge's combo:
http://forums.maxperformanceinc.com/...d.php?t=658767
Maybe he'll run it on a chasis dyno and post results as well.
Looking at the dyno graph at the dip in power makes me wonder what adapter was used to run a 4150 on a 4500 Dominator intake?
Old 02-23-2011, 10:17 PM
Jeff,
no adapters. I have both version of Northwind intakes and both port matched by KRE to my heads.
Old 02-25-2011, 11:05 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
Thumbs up congrats again
i gotta tell this:
Serge's all efforts got paid off,hes got a bad ass Ca. 91 octane pump gas combo now with carefully selected parts & work that has been put together.
he always amazes me with how many combos he has tested on my dyno and seeking for more like all.
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 02-26-2011, 02:16 PM
Todd1035's Avatar
Todd1035 Todd1035 is offline
Send a message via AIM to Todd1035
Looking at your dyno sheet, it looks like you were running it pretty lean. If you can get that AFR to around 13.0 12.9 I bet it would make more. Looks good though. Have fun
Old 02-27-2011, 11:50 AM
shaker455's Avatar
I was wondering about the A/F as well on both carbs?
But I assume Harry K tuned both as stated in Serg's first post.
From my own dyno tuning sessions I've seen cases when the combo likes a slightly leaner A/F than the standard 12.5
Old 02-27-2011, 06:16 PM
Air fuel ratio is fine. 4150 850 carb is barelly over 3 years old. 3 dyno sessions and 1 track day on it. Rest of the time it was sitting on a bench. Yes, it made a little more power compare to my old HP950 but that wasn't why I bought that carb. Sure, if I plug a rear power valve on hp950 it might be very close. Plug on the left is colder. It has about 12 pulls and 40 miles of street driving with a 1050 carb. Plug on the right is from my old motor with 850 carb. Needed a gas mask to drive around. I went back to hp950 carb on my old combo.
Name:	gas mask 006.JPG
Old 02-27-2011, 07:12 PM
JY455V4-Z JY455V4-Z is offline
those plugs look terrible. can't really blame the 4150hp or the domi if they weren't built for the engine. either one of those carbs could be dialed in clean for street use even without a dyno. engine did make good w.o.t power though.
462", 400 block w/displayed caps, mech flat tappet lunati, 11-1 compression, lightly ported #13 heads, e-85, vortech z-trim. 781rwhp@6300rpm on 15.5psi.....blow thru carbs sort of work.
csucarbs.com
Old 02-27-2011, 07:27 PM
shaker455's Avatar
Serg,
Sorry to hear even with instructions you were not able to tune and Harry K seemed to like the carb so much he called me about it right after he dynoed your first combo.
That unit was built, live tested and driven on my own car before it was shipped to you to assure it's proper operation.
I have the same exact carb on my car with the same calabration as I sent you....want me to post my plugs?
That carb I built you years ago has features you don't find in other carbs to provide an A/F balance like adjustable bypass air, screw-in adjustable transition circuit jetting and with those features they result in a balanced A/F @ part throttle/cruise....along with the standard screw-in airbleeds.
Also, I included different size screw-in transition jets that you never even opened as I saw the sealed bags in your for sale post on PZ.
As I recall you drove your last combo on the street with the dist locked despite my advise and it was prone to overheating,
And I believe you had issues with your cam degree install that we talked to Lenny Caverly about.....but that's the carbs fault right?
Despite all that looking at the A/F from a carb that sat on a bench for years it seems Harry K had no problems getting the A/F in an ideal ratio.
Old 02-27-2011, 08:43 PM
J.C.you's Avatar
J.C.you J.C.you is offline
suggestion...if you put it back on the dyno, put a couple of extra washers on the plugs
(3 total) and see what you get.
