Old 02-26-2011, 05:58 PM
cnc's Avatar
cnc cnc is offline
Default SD camera Card differences
Ok couple questions
I have a Sony DSC-W310 Cybershot ....good little camera ...the Card I have in it which I bought with the camera is a Lexar multi use 4GB sdhc card
I tried to put the card into my computer to look at the pics wont read the card....
Put the card in my digital frame it works in there....
I pulled the card from my digital frame which is a 2GB sd card just to check the function of the computer card slot it works ok
Is it because the 4GB card is DIFFERENT from the 2 GB card ( sdhc compared to sd )it wont read in the computer....?????
Only reason I ask is I wanted to erase the 4GB card Pics and I cant because the computer wont let me....looks like I need to erase them another way?????
Thanks for any help people.....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 02-26-2011, 06:02 PM
wytnyt's Avatar
wytnyt wytnyt is offline
do you have an old computer?,,some earlier card readers have file size limits
Old 02-26-2011, 06:05 PM
cnc's Avatar
cnc cnc is offline
I dunno 2-3 years I think not 100% sure ...the slot on the computer MMC/SD
Is there a way to check the date in it easily....
Old 02-26-2011, 07:59 PM
JKGTO's Avatar
JKGTO JKGTO is offline
The SDHC cards wont work in some of the older electronics that are limited to 2GB. HC means high capacity. I read that microsoft has an HC update for the card readers to let them read HC cards but I have not had to investigate that fix. Check into it maybe that will solve your problem. Jim
74 LEMANS GT 350 4SPD MAROON
Old 02-26-2011, 09:33 PM
Card formatted different where the computer can't read it?
Old 02-26-2011, 09:51 PM
wytnyt's Avatar
buy an external sdhc card reader
their really cheap
Old 02-26-2011, 11:01 PM
cnc's Avatar
cnc cnc is offline
Thanks for the info/help guys...Chris
Old 02-27-2011, 05:42 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Can't you just plug in the camera to the computer with the USB cable and navigate to it as a separate drive? (Should show up as the E: or F: or G: drive, depending on how many drives you have in the computer now.)
Other than that, I agree with the cheap external card reader. Should cost well under $10.
Mike
Old 02-27-2011, 08:59 PM
cnc's Avatar
cnc cnc is offline
Yep when I hook up the camera it comes up as removeable disc k
It also shows up a second listing PBMPORTABLE
The software for the camera PMBPORTABLE but cant seem to find a file or folder or whatever to delete the pics from the card.....
I can delete them all off the camera buy chosing multiple delete so might have to just keep looking or just do the camera delete thing.....Chris
Old 02-27-2011, 09:10 PM
cnc's Avatar
cnc cnc is offline
Well Just found out how to do this it also holds/stores the camera as F when i go into it I can delete the pics thanks for the help guys...again....Chris
Old 02-27-2011, 09:31 PM
MYGOAT's Avatar
MYGOAT MYGOAT is offline
I found a quick way of deleting all photos from the camera (SD or SDHC card) is to use use the "format card" function in the camera's menu.
This is for a Panasonic camera but assume all cameras should have this function.
Be careful though as this will wipe ALL photos, videos etc.
Old 02-27-2011, 09:36 PM
cnc's Avatar
cnc cnc is offline
I just looked on the camera and found the format function
I just found it but never went any further, when u select the format function does it ask u what do u wish to do type of thing..???
I'm not ready to delete the pics yet but soon lol...chris
Old 02-27-2011, 10:13 PM
johnsma22's Avatar
johnsma22 johnsma22 is offline
FWIW, you should always reformat the card in the camera after downloading the photos to the computer. When the computer asks if you want to delete the photos from the card after downloading, say no. Then use the format feature in the camera to reformat the card and delete the photos. This makes sure that the card is properly formatted for the actual camera being used. Less chance of file corruption that way.
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 02-28-2011, 07:56 AM
cnc's Avatar
cnc cnc is offline
I did not know that thanks for the tip.....good to know....Chris
Old 02-28-2011, 09:41 PM
MYGOAT's Avatar
On my camera when I select format, it comes up with a warning message saying that all photos on the card will be deleted/wiped. I press "OK" and within a few seconds you have an empty card.
