Old 03-06-2011, 03:33 PM
max 93 max 93 is offline
Default I need help with brakes
I installed a disc conversion and new master, booster, and proportion valve on my 68 bird. I bench bled the master, then I tried to vacuum bleed the brakes with no luck. Then I tried to manually bleed them with no luck. So I disconnected the lines an pressure fed them full of fluid and tried to bleed them again...nothing. I have no pedal pressure and when I open the bleeders fluid will just trickle out with no real pressure. Could the master be bad ? Any ideas. The entire brake system is new.
Old 03-06-2011, 03:57 PM
Dr. Drivability Dr. Drivability is offline
Did your kit come with two pushrods to chose from for the booster to master?
-Jeff
http://www.cardomain.com/ride/3323983
Old 03-06-2011, 05:36 PM
No, the booster, master, and valve came preasssembled and only came with an adjustable rod to connect to the pedal.
Old 03-06-2011, 08:47 PM
SteveOw SteveOw is offline
I feel your pain Max. I am pretty much in the same boat. Although I am getting plenty of fluid at all locations when I bleed. I would believe your pushrod is incorrect and not going in far enough. Hope somone can help out!
69 Firebird Convertable
Old 03-06-2011, 11:12 PM
How do I know what the correct length rod would be ?
Old 03-06-2011, 11:18 PM
racebuicks's Avatar
racebuicks racebuicks is offline
Take the master cylinder off and step on the brake pedal it should move out aprroximately 1 inch I have several longer new ones if you need one.
Michael Garrison
High Torque Racing Auto Body
Meriden Kansas
1970 GS Stage1 (wifes car) 12.78@104 all by herself!!
1970 GS 455-BUZILLA 538 826HP
[email protected] so far thru the muffs
Another bitter rural American clinging to my guns, my God and religion.
I repo & sell buick parts!!
Old 03-07-2011, 07:37 PM
It moves out a little more than an inch
Old 03-07-2011, 09:26 PM
rohrt rohrt is offline
If you bleed the master and it was pushing out fluid I might suspect the distribution block.
What all came with your conversion kit?
It is a stock disc break conversion?
Old 03-07-2011, 09:40 PM
is there a way to test the proportion valve ?
Old 03-08-2011, 12:05 AM
Goin' Topless's Avatar
Goin' Topless Goin' Topless is offline
Send a message via Yahoo to Goin' Topless
is this a 4-wheel or 2 wheel disc conversion?
I had the same issues with a disc conversion, fluid coming out but very little pressure, and I discovered that I was sold the wrong master cylinder.
the master cylinders for disc brakes push out a lot more fluid because they have a bigger piston(s) to move in comparison to the wheel cylinder.
Don't tell people how to do things. tell them what needs to be done and be surprised by their ingenuity. -- Gen. George S. Patton
Old 03-08-2011, 03:51 PM
I did just the front brake conversion. I bought the master, booster, and valve as a unit seperate from the rest, but I specified for front disc rear drum. How can I tell if I got the wrong master ?
Old 03-08-2011, 04:01 PM
Can you post a picture of what you have?
-Jeff
Old 03-09-2011, 10:39 PM
today I plugged the ports right at the master and still no pedal pressure. I would have to say the master is no good. Or should I try to bench bleed it again ?
Old 03-10-2011, 10:59 AM
When you bench bled it originally, did you get good flow from the ports? If so, I'd say you have a problem with the length of the push rod. When you bench bleed it, measure how far the piston goes in the cylinder.
-Jeff
Old 03-10-2011, 07:39 PM
They are sending me a new master. Hope that's it
