Old 03-08-2011, 05:05 PM
nascarnelson nascarnelson is offline
Angry hei wiring
i am sorry i thought i was done. but only have 12 volts with key on. some posts say to jumper the ign1 and ign2 at the switch. this may sound stupid but how would this be done ? again thanks for all your help
Old 03-08-2011, 05:19 PM
webfoot's Avatar
webfoot webfoot is offline
I made a small jumper wire with two spade ends on it.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 03-09-2011, 10:56 AM
question, is there a spot on the starter that i could get 12 volts from with the key in the start position ?
Old 03-12-2011, 10:23 AM
It doesn't have to be 'at' the switch...the two wires could be connected anywhere along their length....it just makes for a neater job at the switch.
If you have the wiring diagram for your car (you should), just look at the entire paths of IGN 1 and IGN 2 and pick a convenient spot to jumper them together.
Old 03-15-2011, 10:47 AM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Be aware that the ign1 wire is a resistor wire. Depending on where you tap into it, your voltage will be lower as you get closer to the coil.
68 GTO ragtop
91 T/A
69 XKE
Old 03-15-2011, 01:28 PM
Yeah, I forgot about that. Some cars it's a resistor but on the GTO it's an actual wire. You will probably have to bypass that completely. I don't know how you'd tap into it. It's a weird little varnish coated wire. Very thin as I recall.
Old 03-15-2011, 01:41 PM
webfoot's Avatar
M&H and AAW sell a replacement wire for HEI conversions that taps directly into the fuseblock and has the correct HEI plug.
-Jeremy
Old 03-18-2011, 04:58 PM
i just want to thank everyone here for all of their help. i soldered two 14 gauge wires to ign 1 and ign 2 on the switch. soldered them together ran one 14 gauge wire to hei dist. thing runs like a champ.
Old 03-19-2011, 01:32 PM
Half-Inch Stud's Avatar
Do it right: replace the underhood pink Ignition wire with a copper wire.
