Old 03-08-2011, 08:53 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Question HELP! 66 lock coding
Are there any qualified locksmiths that can instruct me on how to code this NOS uncoded console lock cylinder? A local key guy said while the key is in the cylinder carefully/slowly grind down all the brass lugs on both sides (not the silver one) untill flush. These older NOS cylinders are tough to find so I don't want to screw this up. Please provide "detailed" proper advice on how to do this.
Also after coding is there only one way this installs back into the case? THANK YOU in advance! Chris.
Name:	66 Console Lock Cyl. (1).jpg
ID:	237080   Click image for larger version
Name:	66 Console Lock Cyl. (2).jpg
ID:	237081   Click image for larger version
Name:	66 Console Lock Cyl. (3).jpg
Old 03-09-2011, 07:51 AM
arbys's Avatar
arbys arbys is offline
I just went through this last fall with my 66. The ignition didn't turn smoothly so I went to a retire locksmith and he told me to the key # from the door lock and then he fix my ignition lock with new tumblers. My advice is find someone over 55-60 that knows oldtime locksmithing.
Old 03-09-2011, 09:38 AM
jd66 jd66 is offline
Default lock coding
i went to my local gm dealer, they had a old hand key cutter, worked for me. jd grim
Old 03-09-2011, 10:56 AM
arbys's Avatar
If I went to the local GM dealer I doubt that they would give me the time of day. If they did give me the time of day they'd probably charge me the minimum shop charge of $75.
Old 03-09-2011, 12:04 PM
JTT99's Avatar
JTT99 JTT99 is offline
Just find a local locksmith, they can work off of your orginal key. While a dealer may be able to cut a new key you need the tumblers matched to the key. I just had a new ignition switch matched to the original key and the cost was $20.
Old 03-09-2011, 01:33 PM
65 provette's Avatar
65 provette 65 provette is offline
I also went to my GM dealer he had the tool just no keys, I gave him the blanks and he made my keys, NO charge!!
Old 03-09-2011, 09:45 PM
IOWA552SLOW IOWA552SLOW is offline
i had to recode the locks on my boss's 69 camaro last summer, no big deal. like most others have said, find a local locksmith and they shouldn't have a problem with it. i do alot better with these in my hands, than i can telling somebody how to do it by looking at pictures.
Old 03-09-2011, 10:38 PM
60sstuff's Avatar
Thumbs up Mission Accomplished!
I tracked down an older lawn mower / locksmith shop and they took care of me. On a NOS "uncoded" cylinder such as mine you must insert the key and slowly grind down all the brass lugs (not the silver one as that holds the cylinder in it's case) on both sides until flush with the cylinder. Going slow is important so you don't overheat the small springs inside. Gently file off any small burrs, clean, small drop of light oil and install in case. Works perfect!
I want to THANK all the above who took the time to offer your help! Chris.
