Old 03-13-2011, 03:01 PM
knauert1's Avatar
knauert1 knauert1 is offline
Default WW motor
Hello, when I turn my winshield wash switch on high it operates correctly when I switch it to low the arm does not go around allowing the wiper arms to go back and forth it only rotates about 1/2" back and forth and will only move blades back and forth about 2"
has this happened to anyone elso?, do I need a whole new pump or what part of this is bad?
thank you
Tom
Old 03-13-2011, 03:59 PM
65WJ's Avatar
65WJ 65WJ is offline
WW is also the engine code for a ra iv.
Make sure its clocked correctly. Do you here a clunk clunk clunk at high speed?
If so it is 180 degrees off.
patrick
Old 03-13-2011, 05:26 PM
knauert1's Avatar
Patric, in this case WW stands for window washer, does this advise still apply, I am completely restoring my '68 triple black GTO convertible and had this area all apart to paint firewall and am in the process of putting it all back together
thanks for your time
Tom
Old 03-13-2011, 05:46 PM
65WJ's Avatar
yep. cool car. there are pics of a triple black judge vert in the judges section.
Did it work before it was taken apart?
Also check the ground. You will see a metal tab on the (iirc) bottom right mounting bolt. Make sure it is clean. If repainted you have lost ground.
does the wiper transmissioin rotate freely by hand?
It been a few years since I did mine. Thats all I can think of now.
Hopefully a couple other guys will chime in and help.
patrick
