Hello. I did a disk conversion a little while back. Well the only thing the kit did not come with was pre bent lines out of the master. The hard part is fittings on the master only seem to work with 3/8 lines. Those are had to bend. I think the kit is like 70+. My calipers are the more modern big single piston gm went too.
Thanks.
Send it! It’s going home on a trailer. |
Is it like this?
http://www.getdiscbrakes.com/RSeComm...ist&endsWith=S Right Stuff Detailing might have what you need prebent, and it is pretty well priced. They have another kit for '68-69 stuff, I'm not sure if that pertains to the OEM 4-piston setup. There's a different kit for 71-72 as well. |
You get the inlinetube kit with the combo valve under the master? I lost one of my lines, called inlinetube and told them what I needed, got both those U shaped lines for $25. If you tell them it was missing from the kit they may send you some replacements.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
Can u post a pic of yours. Want to see what would look like. But no kit was not from them.
