Old 03-19-2011, 08:23 AM
WARCHIEF400 WARCHIEF400 is offline
Default 70-72 GTO/LEMANS
NOS A/C Delco Plugs R44s, and 45's set $60.00 while they last, one set of R44s left two sets of 45's left
NOS A/C Delco PVC $7.50,
NOS Three prong Thermo Switch for rally gauges $150.00
NOS Console lid with push button $400.00
NOS 71&72 Door Guards $250.00
NOS 15x7 Honeycomb trim rings $450.00
NOS SLOTTED NUTS, CORRECT FOR ENGINE COMPARTMENT- one goes on driver's side head stud to secure negative battery, second on top of thermostat house to secure alternator, rear stud on Power Steering unit, two that secure exhaust heat shield driver's side, Additionally one was on shifter linkage on auto transmission - SET OF 5 FOR $20.00
68-72 NOS FRONT WINDSHEILD UPPER STAINLESS MOLDING $150.00
NEW DARK SADDLE CARPET PAID $139.00 SELL FOR $90.00
Oil pressure sending unit for rally gauges $40.00
Water temp sending unit for rally gauges $40.00
NOS 70-72 Wheel well moldings $850.00
pair of used rear wheel molding $160.00
12 bolt Pontiac rearend out of a 70 GTO with 455, Rear out of a Canadian GTO
70 GTO WT 400 shortblock $1500.00
68-72 Front window 3pc stainless moldings $125.00
68-72 front lower window reveal molding $60.00
70-72 rear front fender chrome moldings $30.00 pr.
alternator bracket for non p/s $50.00
68-71 throttle cables $35.00,
69-72 Goldenrod/Tan & Pewter/Gray steering wheels crack free $125.00
68-72 door vents pr. $20.00
68-71 gas pedal & bracket assembly $50.00,
68-72 positive battery to starter heat shield tube,
68-72 pair of 1/4 windows $125.00 pair,
68-72 1/4 window glass chrome trim moldings $30.00 pr.
68-72 single A/C crank pulleys $35.00,
68-72 emergency brake cable set up $100.00
68-72 emergency brake pedal and bracket $50.00
68-72 rear license plate bracket and holder $35.00,
68-72 rear view mirror $25.00
68-72 front armrest bases black $25.00pr,
68-72 door & 1/4 glass regulators $50.00
68-72 hardtop crossmembers primed and painted $90.00
69-72 auto shifters standard $125.00 and up, rachet style $175.00 and up all shifter have been restored, only a few left
68-72 water thermostat housings $15.00 ,
68-72 door hinges $50.00
68-72 points distributors no RA one left $80.00
68-72 wiper arms $50.00
68-72 wiper tranmission assembly $50.00
Fuel escentrics $35.00
69-72 harmonic balancer off low mileage car $50.00,
68-72 blower motors $25.00
68-72 a/c inner and outer boxes with blower motor and heat cores $150.00,
68-72 inner heater box $150.00
68-72 headliner bows $50.00 set
68-72 coils & brackets $35.00
68-72 windage trays $45.00
valley pans $35.00
68-72 stock blue valve covers $25.00 a set
68-72 battery tray $15.00
68-72 a/c brackets
69-72 inside glove box $45.00 very nice
69-72 Gauge&Speedometer cluster $65.00
69-72 Power Front Disk Master Cylinder like new, used during restoration $45.00
70 Judge front bumper in excellent condition of low mileage car preped and ready for final coat of primer $1400.00,
70 Rally gauges off low miles car for 1983 $400.00
70 GTO front bumper grill $50.00
70 GTO front bumper $800.00
70 GTO rear taillights $190.00 pr.
THERMO SWITCH FOR RALLY GAUGES $80.00
1970 one year only alternator bracket $75.00,
70 brake porportion valve and bracket that bolts to power brake booster $40.00,
70-72 Deck lid in nice condition just some surface rust $600.00
70-72 non a/c dash bezel $200.00
assorted stainless moldings,
70 Judge/GTO center core surport bracket $80.00,
70-72 non a/c dash pad $125.00,
70-72 duct work with diffuser $150.00
70-72 dash wiper switch $40.00,
70-72 lower dash metal trim $45.00
15x7 Rally II wheels reproductions $150.00 pr.
15x7 Rally II wheel $65.00
69-72 ac & heater dash control with cable $135.00,
69-72 clock delete dash cover $15.00
radio rear support bracket $15.00
Oil Filter housing $50.00
Tag light & bracket $15.00
Console hinge bracket $15.00
Cowl Screens 3 set $20.00
rear view mirrors $20.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
thermostat housings $20.00
68-72 1/4 glass $45.00 - $65.00,
70-72 door glass $100.00
Pulleys 481040 water pump pulley, 481038 crank pulley, 48057 crank pulley, 6 1/2 X 2 1/2 water pump pulley can't read #s all pulley $35.00
68-74 power brake booster $50.00,
70-72 pillar post covers $45.00
Thermo sending unit for ralley gauges $80.00
68-72 automatic transmission $250.00
71&72 New Power Steering Pump $90.00
15x7 HoneyComb Wheels (4) $375.00
Ralley guages $175.00
71 Passenger side GTO rear taillight lens with dividers $125.00 each
front fender side markers lenes,frames and bracket clips $90.00 without framse & brackets $50.00
FRONT ENDURA BUMPERS WITH FRAME TO BUMPER BRACKETS AND CENTER SUPPORT BRACKET $325.00,
Complete set of 72 GTO seat belts $250.00,
72 throttle cable $15.00
71 & 72 driver's side headlight assembly $150.00
71&72 headlight assembly set $225.00
71 & 72 ENDURA BUMPER TO FRAME BRACKETS $125.00,
71 & 72 ENDURA BUMPER TO CORE SUPPORT BRACKETS $80.00,
71 & 72 front center support bracket $100.00
71&72 POWER STEERING PUMP with PULLEY & BRACKET of 72 GTO $90.00 ,
original Pontiac oil pans $40.00-$65.00
72 front parking lens and bezel $35.00
71&72 ALTERNATOR/POWER STEERING BRACKET $50.00
72 & 73 400 SHORT BLOCKS $500.00,
Torker intake $150.00,
aftermarket chrome valve covers Elderbrock $40.00,
a set MALLORY 7MM SUPPRESSION SPARK PLUG WIRES $25.00,
AFTERMARKET FLEX FAN $15.00,
new points and condensers
E-mail at [email protected]
Timmy Mallory
Timmy Mallory
Old 04-09-2011, 01:47 PM
DARK SADDLE CARPET HAS BEEN SOLD!
Timmy Mallory
Old 04-10-2011, 05:08 PM
1971lemanssport 1971lemanssport is offline
Default interested in the carpet
did you sell the dark saddle carpet for the 71-72 lemans?
Old 04-10-2011, 08:51 PM
Yes the carpet has been sold, just waiting on payment.
Timmy Mallory
Old 04-10-2011, 11:29 PM
OrbitOrange OrbitOrange is offline
Hey Timmy, Ill take this.
Old 04-13-2011, 12:32 PM
spurkman spurkman is offline
Looking for 72 350 2b throttle bracket
Old 04-14-2011, 05:47 AM
pm sent
Timmy Mallory
Old 04-23-2011, 03:25 PM
Petegto Petegto is offline
Default gto 72 horns
Tim
Would you have a set of horns for my 72 P/N 9000239 and 9000911?
Peter
Old 11-07-2011, 05:56 PM
mogluv545 mogluv545 is offline
Send a message via Yahoo to mogluv545
Default steering wheel
need a 72 goat sport steering wheel?????? jim..... [email protected]
Old 12-06-2011, 12:56 AM
70temp455 70temp455 is offline
Send a message via ICQ to 70temp455
Default parts
Prrice and availability :
Oil pan ?
Valley Pan ?
Timing Cover ?
thnx
