Old 04-03-2011, 10:46 PM
61 vent 61 vent is offline
Default Jetaway transmissions/ 315
Jetaway transmissions / 315 not the Slim Jim. How did this 4 speed transmission work? Did it actually have 4 speeds? or did the converter lock up? How would one of these compare to a modern 4 spd automatic? Would I be better off to rebuild or to swap to a newer 4 spd auto? Thanks for any input
Old 04-04-2011, 12:37 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Jet-Away (Oldsmobile's name- can't remember Pontiac's name) were truly a 4-speed. However, the small extra fluid coupling (they were called Dual-Coupling Hydramatics) took the place of a previous clutch in the older Dual-Range transmissions. A shift into 2nd or into 4th gear involved filling the empty front coupling with fluid, so these shifts were "soft"- and no amount of internal modification could improve them much. They aren't "bad" transmissions, and some owners really like them. But like any old Hydramatic, they can be difficult (expensive) to repair or rebuild.
Old 04-04-2011, 07:00 AM
stevep's Avatar
stevep stevep is offline
Pontiac called it a Strato Flite and a Super Hydramatic.
It is in direct drive in 4th. With a modern 4 speed, it is in OD in 4th.
Old 04-05-2011, 10:54 PM
59safaricat 59safaricat is offline
Fantastic transmission if you can find somebody who really knows their way around one to rebuild correctly. Love the hell out of mine! It's the only automatic transmission I have ever warmed up to. Drove 'em all: Torqueflite (904 & 727), C-4, C-6, Cruise-o-matics, Powerjoke (powerglide) TH-350 and 400's....the list goes on.
Old 04-05-2011, 10:59 PM
Engine-Ear's Avatar
Also, the four speed automatic, as found in Bonneville & Star Chief, has 1st and 2nd gear mated together internally. When the gear selector is in "L", you get both. You are out of 1st by 10 mph. If you have one of these and you pay close attention, you can hear and feel the embedded shift.
Just to clarify, is this idea for a '61 Vent? If so, you need to open up your trans tunnel with at least a BFH, if not a torch.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 04-07-2011, 12:50 AM
No this would not be for a 61 Vent but a 62 Bonne wagon
Old 04-07-2011, 09:46 PM
Engine-Ear's Avatar
Cool. Bonne Safari is the lowest regular-production b-body in '62 ... ENJOY!
Old 04-26-2011, 04:51 PM
Is the super hydromatic trans made of aluminum or iron?
Old 04-26-2011, 06:08 PM
stevep's Avatar
From 61-64, Pontiac Jetaways were all aluminum. A few 64 Pontiac Jetways did have a cast iron case. I have seen 2.
Old 04-27-2011, 12:03 AM
Thx
