Old 04-05-2011, 10:38 PM
70temp455 70temp455 is offline
Send a message via ICQ to 70temp455
Default 71 Olds Cutlass Rear end in 72 LeMans
Broke my P 8.2 and got a Cutlass 8.5 10 bold from the local Classic Car parts yard. The guy said it would bold right in. It did, the drive shaft didn't !
I'm having it shortened 1-1/2 " and ahving new U-joints installed.
In preparing the rear-end for insertion I drained and the gear lube and relaced the gasket and cover with a Summit Chrome cover and POR-15 the rear drum to drum.
41/16 = 2.56
Anyone know what other gears will fit this carrier ?
Thanks in advance !
Andy
Old 04-05-2011, 11:40 PM
marxjunk marxjunk is offline
2.41 to 2.76...with out any mods............
Old 04-06-2011, 03:24 AM
GStage1's Avatar
GStage1 GStage1 is offline
GM used that center section up to 1987....so you can use any set-up you want...best bet is the full size 80-87 wagons...many have 3.08-3.23 gears and some have posi units. After 1987 GM went to 30 spline axles so those carriers won't work.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 04-06-2011, 08:43 AM
2.41 to 2.76
Old 04-06-2011, 01:46 PM
The 8.5 10-bolt corporate rears used only two differentials or carriers.
One for 2.41 & 2.56, the other for 2.73 and higher numerically.
That's it.
Old 04-06-2011, 05:26 PM
Default screwed
So I'm screwed as far as far as making any worthwhile change to the rear end and carrier I have now.
Olds site saide a 70-81 camaro carrier and gears would work but do I need the JUST the carrier and gears or would I need to swap the entire housing ? I'd assume a camaro rear would be a bit narrower and would not fit a LeMans, so just the carrier and gears then ?
Thanks Guys !
Andy
Old 04-06-2011, 05:51 PM
Just the differential needs to be changed, not the entire axle housing.
Forget about using any Camaro/Firebird housing, you can't swap a leaf spring housing into a car that needs a four-link housing.
Just use the carrier and gears.
Old 04-06-2011, 07:51 PM
67drake's Avatar
67drake 67drake is offline
I was in the same boat. I picked up a 71-72' Buick/Olds 8.5,but it had a 2.56 posi in it. I set it up with 3.42 gears and a ring gear spacer behind the ring gear,so that I could use the 2 series posi carrier with the 3.42 gears.
That rear has been sitting in my garage for 2 years now because I decided NOT to take the chance of using the spacer behind the ring gear. Too risky with the way I drive my GTO. I picked up a 3 series Eaton posi just yesterday,so I'll be redoing it all in the next couple weeks.
Those 8.5 rears are supposed to be stronger units then the 8.2's that came in our cars originally,so you will have a strong set up when your done (If you DON'T use a spacer!). I've heard if you put in a 30 spline carrier and axles,as opposed to the 28 spline that came in them stock,they are as strong as a 12 bolt rear.
As B-man said,the 8.5 carrier and gears from a Firebird will swap over,just not the housing. Also the carriers/gears out of many GM 8.5 rears from later years will fit in the early 70's housings. I forget the cut off,but somewhere in the late 80's as I remember.
‘55 Catalina
Old 04-06-2011, 10:29 PM
Default Now to find one
Don't know where, but I'll be lookin fur One.
Any Ideas ?
Thanks again Guys,
Andy
GStage1's Avatar
Andy,
You should recheck your measurement for the driveshaft.....I have done many changes from 8.2 to 8.5 and always need to shorten the d-shaft 7/8-1......your 1 1/2 is a little too much to take off...you can look up the driveshaft measurement in the assembly manual.....I think it is 56 3/8 from center to center of u-joints.
George Nenadovich
Old 04-06-2011, 10:35 PM
GStage1's Avatar
You can get posi units from many GM cars.....8.5" rear was the standard rear for many cars........except 78-87 G-body (Monte Carlo, Cutlass, Grand Prix, Malibu, Regal)
1988 is the cut-off year for 30 spline axles...so stick with pre-88 rear and you will be set.
George Nenadovich
Old 04-06-2011, 11:37 PM
Default 1-1/2 off Driveshaft
I set it down and measured like the Drive shaft guy said to do. It came out to 1-1/2 needed to come off. Now that it is shortened and sitting down, the shaft is about 3/8 further out of the trans than it had been(which was about 1" out).
Do you think the extra 3/8 will be an issue ?
Thanks,
Andy
Old 04-07-2011, 08:37 AM
GStage1's Avatar
3/8" should not be an issue.
George Nenadovich
Old 04-07-2011, 09:24 PM
Default Drake ? and George
Drake, wanna rid yourself of the 2.56/3.42 posi ?
George, The DS measured 56" pre-shortened. The guy said (and I saw it elsewhere) to have the car with the weight down on the axle (as if), measure from output shaft tip to the top of the Yoke. That was 56.75. They subtract 2.25 for the slip yoke which gave us 54.5 (1.5 less than stock).
I agree (in hind sight) 1" would have been perfect. I had measured both rears from the axle tube to the yoke u-joint and came up wit darned near 1" longer snout on the 8.5 than the 8.2. There's the 1" again.
I read reference on the Old site that the saft needed to be 55" (1" again)
I didn't think it would be an issue but wanted another opinion before I insisted the place FIX the mistake.
Andy
Old 04-07-2011, 10:02 PM
If you're changing the carrier or diff to get into the lower gears you might consider a new Eaton posi. They come in both 28 and 30-spline versions, the one pictured is a 30-spline with 3.42 Yukon gears teamed up with Moser alloy axles so it can take a beating:
Old 04-07-2011, 11:19 PM
Default splines ?
So, when carriers advertise "splines" they are refering to the splines on the axles ?
And, How many splines on my stock Lemans axles ? 28 ? 30 ?
Ahh, so much to learn !
Thanks,
Andy
Old 04-08-2011, 12:48 AM
The spline count refers to the number of splines on the axles, these engage into the splines in the side gears on the differential. The greater the number of splines, the stronger the axles will be.
The Cutlass 8.5 rear end you picked up has 28 spline axles. They are true heavy-duty axles already and can take some abuse, but of course for some extra cash you can get aftermarket axles that are even stronger if you plan on having high-horsepower or like to beat on your car a lot.
I had the 8.5 rear end pictured above built for a car that will have around 480 horsepower. I decided to put some heavy-duty parts in the rear end for added insurance against breakage.
Old 04-08-2011, 07:37 AM
67drake's Avatar
Got your E-mail. Check your personal messages.
‘55 Catalina
Old 04-08-2011, 04:16 PM
russosborne's Avatar
russosborne russosborne is offline
Ok, I am feeling really stupid right now, but I am not quite sure what you guys mean by changing the differential. Might be my old Ford history again, but when I think of differential I think of the fords where you remove the entire "pumpkin", and I know on the BOP you can't do that.
Is "rear end gears" = "differential" what you guys mean, or am I still cornfused?
This is what got me
"The 8.5 10-bolt corporate rears used only two differentials or carriers.
That's it."
Sorry, my brain hurts, it's been a long week here.
Thanks,
Russ
Old 04-08-2011, 04:29 PM
67drake's Avatar
Differential= http://www.drivetrainspecialists.com...duct-1986.html
I can understand your confusion. I see people interchanging the terms alot. Differential is usually the ring gear carrier,and the parts of it-spider gears,posi clutches,ect. But I do see people use the term differential when they are referring to the entire rear end housing.
‘55 Catalina
