Old 04-10-2011, 03:02 AM
cuz68's Avatar
cuz68 cuz68 is offline
Unhappy Wet water spring
How can you tell if you have one? I have water runing down one side of my drive way for over six weeks, This is the first time that i have saw this in 16-yrs? we have had a lot of rain tho. Thank you Randy.
Old 04-10-2011, 08:34 PM
stimpy stimpy is offline
we have one in front of the other building if we get more than 3 inches of rain in a mater of a week it will seep outof one spot till the groound drys up . we had to install a perforated pipe on the exterior of the building to the sump pit to keep the ground dry you can actually see the water push up when it rains ( we though it was a leak from our well to building pipe) . and the building is higher than the surrounding area , its due to high bedrock in the area . only way to alieviate ist it to dig and make a drain for it .
Old 04-16-2011, 09:14 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
Keep an eye on Your water pressure or or water bill just to make sure You don't have a leak some where....also check any water lines/routes coming into your home?We have had a lot of rain here too and it takes a while for it to quit especially if the ground is really saturated!
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 04-17-2011, 09:37 AM
limejudge69's Avatar
Randy, Are you on city water or well water? If you have city water, call them and they will come out and check for chlorine. That will tell you if it's a water leak or ground water. If you are on well water, you may have to dig until you find it.
Old 04-18-2011, 01:50 AM
cuz68's Avatar
Unhappy
I am on city water that the county buys from the city, I live in the county with a lot of old pipes that leak a lot, That has been run where i live for many years, not on my land tho, My water bill runs a round $58-69 per month Got one for $106 in dec of 09/ SAD. I only live about 1/4 mile from the city, I live in carter county, I have no leaks on my land. IM in distric 4 that has the highist water bills in all of carter county. Thank you all for your replys.
Old 04-18-2011, 09:03 PM
Mike S's Avatar
Mike S Mike S is offline
Wow! That is a high water bill. Is that normal in your area? Here in NJ my bill is $7.95 a month. That is a family of three and not watering the grass. This the lowest they charge, Then they charge for eveything over a certein gallons a month.
Are you sure you don't have a leak after the meter?
Old 04-19-2011, 01:46 AM
cuz68's Avatar
Unhappy
Yes no leaks, My neighbors run around $158- 278 per month. I have a family of 3 also, Our water comes from the TVA.
