For Sale 1971 Pontiac 455 HO Engine for Trans Am. Heads Are #197. Intake Runners Have Been Smoothed.
Engine is completely rebuilt and period correct. Engine Code is YE 455 HO 4 Bolt Main Block and Date is 9/02/70, Heads Are 12/08/70 and 1/08/71. Ready to drop into car and go, just add fuel pump, carb and oil and dist. Parts include New Forged Connecting Rods, Keith Black Hypereutectic Pistons, Harland Sharp 1.5:1 Roller Rockers, Comp Cams Push Rods, Blue Racer Camshaft .442/.465 Lift, 272/282 Duration, Clevite Main Bearings, Federal Mogul Rod Bearings. Double Roller Timing Set. Block and Heads are Coded 3 months apart for Automatic Car and are Early 71. Also Comes with New Set of Ram Air Restoration Enterprises 2 1/2" Collector Round Port Exhaust Manifolds. Call Or Email With Any Questions. I Have All Receipts. Motor Mounts Are Not Included. $12,000 OBO 515-360-2249 |
Is this available?
I will check the numbers. If you don't mind please use my email. [email protected]. Thanks for taking the time to look and help me out. Have a great day! Ronnie
Do you know what car this came out of? Can you post the VIN that is stamped on the block?
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1996 Trans Am WS6 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 |
Block came out of a 71 Trans Am that was once located in DM Iowa, car is now believed to no longer exist. Numbers that I can read are C or Q 133134, and 107657
