Old 04-12-2011, 09:21 PM
Mook Mook is offline
Default Ram Air?
Can anyone tell me the difference between the lower pan or any other parts for the ram-air set up between a 69 and 70? thanks
Old 04-13-2011, 08:38 AM
The Boss's Avatar
The Boss The Boss is offline
Difference between 69 & 70 are in the bowl area only - 70 had more dimples & a hole filled with a rubber plug.
Difference between RA III & RA IV are the Heat Risers - RA III had one on the driver's side, RA IV had two - one on each side with the passenger side tube longer (taller).
First pair of pictures are 69 RA III, Second pair are 69 RA IV.
ID:	241032   Click image for larger version
ID:	241033   Click image for larger version
ID:	241034   Click image for larger version
And go racin' in the street.
Old 04-13-2011, 08:48 AM
Thanks Boss, so either the 69 or 70 pan should not have any issues fitting on a 69 carb? Thanks
Old 04-13-2011, 09:11 AM
The Boss's Avatar
Both will fit both years.
