Old 04-13-2011, 03:06 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Default Center Console for Manual 68-69
So pretty much the consoles for the manual transmission equipped 68s and 69s are pretty hard to find and when I have seen them on ebay, even in rough shape they go for a pretty penny.
This brings me to my thought.
I have an automatic console that I traded for a Camaro console back before I knew better.
I was wondering if anyone had ever modified the top plate on the auto console to be a manual trans console?
I figure it couldnt be too bad. I could remove all teh fake wood grain cut the metal and weld in a piece of sheetmetal, cut a whole using the new fake wood grain sticker as a template.
anybody?
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 04-13-2011, 04:38 PM
spb350 spb350 is offline
I just bought a 4 spd console that someone had put the stickers on. I'm not very impressed at all. The wood grain looks OK for a driver but doesn't look or feel anything like the original. The guy that did it also did a terrible job around the corners, its very noticeable. I'm going to pull off the stickers when I get a chance to see what the original woodgrain looks like. The rest of the console is in great shape.
73 Trans Am Red/White #'s match 4spd...... sold
69 Firebird 400 conv #'s match AT Blue wht/wht
06 Vette conv Red/Red/Blk
Old 04-13-2011, 05:10 PM
when you take it off can you snap some pictures of the bottom of that plate, I know it has 3 screws underneath to hold that shift plate.
also could you take measurements?
Thanks man
Old 04-19-2011, 12:15 PM
Nobody else has ever thought of this?
Old 04-19-2011, 01:17 PM
rohrt rohrt is offline
I'm interested in how this turns out.
Old 04-20-2011, 08:32 AM
boater bill's Avatar
boater bill boater bill is offline
I have 2 Auto console with one of them being pretty hacked up by me putting in a shifter that wasn't correct for a console. In my research, the burlwood overlays are the biggest issue. Cammer-6 has something that best matches the original, but is EXTREMELY expensive. Someone here just used real burlwood walnut and veneered it to the console pieces with fantastic results.
I have thought about making a new top plate with the opening for the shifter cup and then using the console overlays for while, but haven't gotten around to it. Right now I have my Hurst competition Plus and T-handle sticking through an Auto console with an oversize boot. Less than ideal, but I have other projects I am working on that are more imporatant.
Old 04-20-2011, 10:10 AM
the overlay isnt going to be an issue for me, I am just going to paint the top plate, and the compartment door, gloss black to match the exterior, never been a big fan of the wood inside the Bird.
I have been looking at pictures of a manual console, but its not too clear since the picture size is small
it looks like that shifter plate sits inside the original square
Old 04-23-2011, 09:49 PM
kmz68bird kmz68bird is offline
Here is a link to a few photos of the console differences. I may be tackling the same project soon. Hope it helps out.
https://picasaweb.google.com/283falc...We2fy5xIq2ngE#
Old 04-23-2011, 10:06 PM
If you are going to be painting the fake wood grain you might want to even consider buying the 67 manual shifter plate and 67 shifter boot. It will look like a 67 manual console then. If you are not concerned with having it look year specific?
This is the route that I might go with. Just another idea.
Old 04-23-2011, 11:41 PM
ponchopower69's Avatar
ponchopower69 ponchopower69 is offline
I read some where that the 68-69 manual console are nothing other then a 67 console with the 8-9 style top bolted to it. They also all share the same demensions. I too am looking at doing this. But plan to make my own top since I do not want the burlwood. I will see if I can find where I saw this at and post up a link.
Old 04-24-2011, 08:35 AM
Cammer-6 Cammer-6 is offline
read the many posts on consoles and youll see this mentioned time and again.
It can be done to make the 4 speed hole out of a auto one with a little metal work.
Had a local metal stamp place check into making 4 speed tops.They wanted $75K to tool up.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-24-2011, 02:19 PM
Thanks that is awesome
I already have the 68 AT console, and I already extended the hole to fit my shifter. Then after lots of research i found out that it was an AT console. But I like the look of the top plate on the 68, not the 67
what is a 8-9 style?
wow 75K
Old 04-24-2011, 05:55 PM
The 68-69 style is the top with the offset oval for the manual shifter. The 67 style was a console with the large square opening for the manual shifter to go through.
Old 04-25-2011, 08:13 AM
yea I know, but as i already said, I have the 68 console with the AT top plate, so why not just modify it
Old 05-16-2011, 09:53 AM
Well I finally got my hands on a manual top plate, but I am gonna take some exact measurements and make a template for anybody interested.
