Old 04-14-2011, 09:23 AM
Half-Inch Stud's Avatar
Cool Removable 68 GTO doors
Has anyone cut the Door hinge pins, to be able to say "it's easy" to have removable doors?
I have me reasons to need removable 68GTO doors.
Old 04-14-2011, 09:43 AM
marxjunk marxjunk is offline
look into race car stuff, you can buy hinges that you open the door, and lift up the door and it comes off....
Old 04-14-2011, 10:02 AM
Want to know about the original GM hinges, particularly if any complication occurs at the Spring-loaded Paw.
Old 04-14-2011, 10:33 AM
well..they are servicable, you pull the pin to replace the bushings, so why not...theres a tool to put the spring in, but you may not need the spring, it holds the door open, other than that its along for the ride...ive put literally 100s of bushings in the hinges over the years
Old 04-14-2011, 02:23 PM
I want to retain the Spring& Paw operation.
Car is done, & hinges are excellent: So thinking about Replacement Pins with cotter-style pin-pulls
Old 04-14-2011, 07:53 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Not being smart here.... Why do you need to take the doors on and off.????
Send it! It’s going home on a trailer.
Old 04-15-2011, 01:43 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Is this just for a one time deal? I installed my top pins upsidedown so the doors could be removed at painting time while leaving the front clip installed. It works great. I wrapped the springs with wire, then cut the wire to let them snap back in palce. This is easier said then done, but it works well.
68RT
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 04-15-2011, 06:19 PM
""""""I installed my top pins upsidedown so the doors could be removed at painting time"""""
Will investigate that. Thanks.
Old 04-15-2011, 06:27 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
ive been pondering away at just how id go about painting my jambs and such and then reassemle without scratching stuff up trying to re assemble the front!
i will be investigating this idea too
