Old 04-23-2011, 05:16 PM
jims68ragtop's Avatar
jims68ragtop jims68ragtop is offline
Default Differential
Hi,
I have attached three photos. I have three questions:
1) What kind of diff do I have? Standard? Posi-Trac? Safe T Track?
2) What is your opinion of the wear on the gears?
3) Where can you get the Multipurpose Hypoid Gear Lube? Or, If I have the Safte T Track diff, where can I get the special lube required?
Thanks,
Jim
ID:	242291   Click image for larger version
ID:	242292   Click image for larger version
Old 04-23-2011, 05:47 PM
goatless's Avatar
goatless goatless is offline
1. It's an open rear.
2. I'm no expert, but the wear pattern looks good to me.
3. Your local auto parts store will have the gear oil you need.
1966 GTO
Old 04-23-2011, 06:26 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Perfect.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 04-23-2011, 07:01 PM
Simple Man's Avatar
)1 Standard
)2 Good wear
)3 Any reputable auto parts store.
be a simple...kinda man.
Old 04-24-2011, 12:45 PM
Thanks for your responses.
How do I switch the rear end to posi-trac? Do I need a whole axle assembly, or can it be done inside the existing diff?
Old 04-24-2011, 03:45 PM
68gtoMN's Avatar
Differential housing and axles are the same. The center section is what needs to be replaced. Best Bet is to go aftermarket. Unless you want to purchase new gears, find a posi unit that supports your current gears. Some are Auburn, Detroit Locker... Perhaps call a company like Moser or Currie Enterprises for input...
'70 LeMans Sport
Facebook Event
Old 04-24-2011, 04:11 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
If you take an axle shaft from a 4 pinion posi and put it alongside an open rear axle shaft you'll see the posi shaft is larger diameter,,dose not neck down like the open one.
Leo
Old 04-24-2011, 07:59 PM
PaulatFast PaulatFast is offline
But will interchange just fine.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
