Old 04-25-2011, 04:07 AM
nWo hogan nWo hogan is offline
Default Need help swapping out a Crossfire for a 350 Goodwrench and a 700r4 Transmission
Hey guys ! I'm a newbie here. Looking forward to share our experiences together and further our knowledge regarding Pontiac. Hope all is well
So I have my 82 Trans Am, 140,000 miles, Crossfire engine and 200C Tranny. It has been idling rough and at 65 mph, the tranny is at 2600 RPM. I only have the car for a week, but with the miles and so on, it will cost a lot to rebuild the engine and get the Throttle Bodies. So I need help swapping the Crossfire out and putting in a GM Goodwrench/TargetMaster 94 production date Crate Engine Cast # 10066036 with 22,000 miles and a 700r4 Transmission. I paid $ 600 for everything, and the engine came with - fully dressed. holley four barrel carb, Edelbrock dual plane intake, HEI distributor, ram exhaust manifolds, starter, fuel pump, water pump, alternator, ps pump. I think for swapping the Tranny I need - kick down cable, non-locking converter or lock-up kit, drive shaft, tranny mount, torque arm -? I might scrap the Holley.What do you think about the Holley that came with it ?
What do you guys think I should do with the engine -? New gaskets,new starter,water pump and so on ? Also,when I'm ordering parts, do I just order for a V8 Chevy 5.0 -? Or say Goodwrench Replacement engine -?
Any and all help will be great. Thank you very much
Engine specs :
350 Cubic inches 4.00" Bore, 3.47" stroke
8.0:1 compression ratio.
250 HP @4300 rpm 350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036 2 piece rear main seal 4 bolt main
Crankshaft- part # 3932444 Nodular Iron 1985 and older flywheel bolt pattern.
Connecting rods- Part # 10108688 Powdered Metal
Pistons- part#12514101 Cast Aluminum
Oil Pump- part # 12555284 G.M. High Volume Pump
Camshaft- Part#3863151 Hydralic Flat tappet
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194° Exhaust Duration @.050"- 202°
Lobe Seperation-112°
This cam Has a mechanical Fuel Pump Lobe. This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808 casting #33417369
1.94" Intake valve , 1.50" Exhaust Valve 76cc Combustion Chamber
7 Bolt style Exhaust Flange Standard 85' and prior intake manifold bolt pattern.
Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
nWo Hogan is online now vBGarage Page Report Post Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
nWo Hogan
View Public Profile
Send a private message to nWo Hogan
Send email to nWo Hogan
Find More Posts by nWo Hogan
Add nWo Hogan to Your Contacts
Old Yesterday, 02:31 AM #2
nWo Hogan
nWo Hogan's Avatar
Classifieds Rating: (0)
Old 04-25-2011, 11:32 PM
Hey guys
Old 04-25-2011, 11:59 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
you will probally get more help in the 82-02 firebird/trans am tech forum than you will in the race section, since most who post in the race section are traditional pontiac power only.
for what its worth, id would at least replace the simple stuff, the oil pan gasket,valve cover gasket, probally new water pump and thrmostat too, maybee even the rear seal just for the sake of doing it. id have a look in the pan make sure theres nothing inside screaming out for further inspection
