Old 04-26-2011, 03:33 AM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Default Power Steer
Was checking my P/S fluid today and noticed it was a brown color. It should be red correct?
Is there a easy way to drain and refill the pump without removing it?
Old 04-26-2011, 03:46 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
actually regular power steering fluid is sorta clear, usually people use trans fluid which is why you normally see red in it, the clear fluid dirties up quicker but may actually be fine, chances are, if you did drain it all out and put fresh fluid it would be dirty lookin again, unless your planning to flush the system out of the box and lines and pump
Old 04-26-2011, 10:25 AM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
I used my wife's turkey baster ... once
68 GTO ragtop
91 T/A
69 XKE
Old 04-26-2011, 02:36 PM
69Customs's Avatar
69Customs 69Customs is offline
Hope you cleaned it before Thanksgiving! (LOL)
Old 04-27-2011, 02:55 AM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
AS the old saying goes if it is not broke dont fix it.
