Hose bulging
If the upper rad hose is bulging and its relatively new what should I look for next ? Poor circulation in the radiator ?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers.... |
Check this first......
Is the bottom hose collapsing? That could do it too. Bad hose or the spring inside it is broken, missing, or just plain shot. If the above is ok..... Could be a restriction in the radiator..... or a bad new hose. Flush out the radiator really good or better yet... take it to a radiator shop and let them do it, plus do pressure test on it. It'll cost you a few bucks but it'll give you peace of mind and you'll know what's wrong or not. If that's it, have it recored if the upper and lower tanks are still good. I went thru that and it was the best thing I did seeing I got an SLK core the has more tube and fins than the original. Unless someone looks realy really close they can't tell it from an original.
I've run into recent reproduction rubber parts that failed almost immediately....like they were not cured or formulated correctly. Had a set of tie rod boots crack, split, and disintigrate in 6 months after installation on a chassis...this was just sitting there on stands, nut even greased yet. Also had a repro shift boot break into two pieces inside a month. Could be a bad hose.
Jeff |
Any chance you got carb cleaner on it?
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
no. no cleaner on it and from feel it seems the lower hose spring is intact. ill pull the rad and have it cleaned or repaired.
i think it might be my cap. the pressure relief does not seem to be working....
