Old 04-27-2011, 09:51 AM
64catalina 64catalina is offline
Default Engine Swap issues 64 Catalina
New member looking for help. I am restoring my 64 Catalina convertible and attempting to put a mid 70's big block 400 in. I have the engine setting decent but...
with the factory headers need to make engine fit I have a clearance issue with the pitman arm. I can turn right but not much left, hitting header.
Any suggestions?
Old 04-27-2011, 10:49 AM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
When you say 400 big block,... did you put a Chevy motor in? All Pontiac V8 engines have the same external dimensions from late 50's to early 80's
Ron
Never trust anything that bleeds for five days and won't die.
Old 04-27-2011, 10:51 AM
Deadhead's Avatar
Deadhead Deadhead is offline
Long branch manifolds from RARE if it's a Pontiac 400.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 04-27-2011, 11:10 AM
When I got the car it had a small block 350 in it. Obviously not the original motor.
I wanted to get back to all pontiac. And yes they are R.A.R.E. factory headers.
The physical engine dimension is not the problem. The blocks in reference to the motor mounts changed at some point. Thinking 1970 ish and nether the 64 or 75 style mounts would work. 64 would not bolt to block. 75 made engine sit to high can't close hood.
so I made some mount brackets to work with mounts.
The headers fit real tight between starter and steering box, a little to tight to turn left much.
Pat
Ron
Old 04-27-2011, 11:11 AM
Thats correct, nice headers and nice fit or so I thought.
Old 04-27-2011, 11:58 AM
Engine-Ear's Avatar
64cat/Pat: Welcome to the PY board!
OK, (still) assuming you have a Pontiac 400 as I type this, use the '64 motor mount. The '70s blocks have five holes drilled in each side of the block - one style for F-body and one that is compatible with the early mount like your '64 was born with.
Using homemade mounts + RARE's LB HO manifolds is uncharted territory. As such, posting pics of your arrangement would also help a lot.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 04-27-2011, 12:49 PM
I will try and get some pics posted. The 64 mounts would no match up. if i had 2 bolt holes I would be OK. I think the 400 came out of a 75 Grand Prix.
Pat
Old 04-27-2011, 08:08 PM
Engine-Ear's Avatar
I am not an expert, but to the best of my knowledge, if it IS a 400 it has 5 holes on each side. Then again, a block as late yours will (should?) have the displacement cast into the side of the block.
Old 04-28-2011, 12:26 PM
gregneun gregneun is offline
Default Motor Mount Holes
Not sure but I got this:
Motor mount holes
Ok, I didn't say this was easy, but check out the number of drilled motor mount holes on the block. Go ahead get down there and look. Pontiac blocks with only 2 bolts holes per side were cast before 1970. Based on my observations,1964 to 1969 Pontiacs engines were all "2-holers." Blocks cast in 1970 to the last of the run (1978) had 5 holes per side, at least in theory. Some blocks, like my 400 that's in my 79 TA 6.6, is different (below left). It is a 3-holer with two blank pads (no holes). These pads can be drilled and tapped if necessary to accommodate a different engine mount. The other earlier block (to the right) is a "5-holer." These are all drilled and tapped.
from here:
http://www.pontiacstreetperformance..../blockIDa.html
Old 04-29-2011, 12:41 PM
The motor mounts I think I have worked out took a little welding and some drilling seems to sit OK.
The pitman arm is the biggest issue right now. I am wondering if the 68 firebird pitman is possible. It has kind of a banana shape to it which would solve my issue.
Thanks for your info.
Pat
Old 04-29-2011, 02:17 PM
Pat,
Where in Cincy are you? I think I may need to make a trip down there this weekend and see what is going on. If you have a Pontiac motor, correct motor mounts, and RARE headers.... you should be fine.
What I'm trying to stay is STOP!!! lets check the list.
PM me your address and phone number
Ron
Old 04-29-2011, 03:02 PM
Stuart's Avatar
Stuart Stuart is offline
Yeah, I'm wondering about this as well...everything should all just bolt together and fit in that car. Which R.A.R.E. manifolds are you using, their long branch manifolds? They shouldn't get in the way of the pitman arm.
Old 04-29-2011, 03:07 PM
I agree, I have the long branch headers. I even called Paul at RARE.
I don't know if its because its a drop top and the frame is thicker or what. it will turn but its like having 24" rims or something.
Pat
Old 04-29-2011, 04:06 PM
Default Candian Pontiac?
I know it's reaching, but it would explain the Chevy engine and "not so fresh feeling" of the Pontiac engine.
The Candian units have an X frame like the Chevvies. The American made pontiacs have perimeter rail frames.
May need the older harmonic balancer (3 piece) to help with that steering fit.
Good luck,
Greg
Old 04-29-2011, 08:36 PM
I'm going to give Pat a call tomorrow and go down and take a look-see. He's only about 30 min from the house. I'm more curious about how they used the Pontiac motor mount pad on a sm 350.
I'll take a look and report
Ron
Old 04-29-2011, 10:11 PM
Chances are they used an early chevy mount.
Mike
former." --Albert Einstein
- Winston Churchill
Old 04-30-2011, 09:20 AM
I just spoke with Pat, and it sounds like the original crossmember engine pad mounts have been removed/replaced. I've got them here in the shop that he can reweld in....
I'll (we'll) update as we know more
-r-
Old 04-30-2011, 09:55 PM
Engine-Ear's Avatar
Question wha wha what??
... it sounds like the original crossmember engine pad mounts have been removed/replaced. -r-
W T F ???
Old 05-01-2011, 09:09 AM
Mike,
Yes they did use sb chevy motor mounts welded in.
Ed,
when the sb350 was put in they erased all evidence of the original motor mounts/pads.
Ron was cool enough to stop by and shared his wealth of knowledge I will post pix of engine block later today camera battery died.
Old 05-01-2011, 11:07 AM
Default engine swap issue
Here are the pix of the block and cross member that is giving me all kinds of grief to get engine in right position which should solve the pitman arm issue.
ID:	243087   Click image for larger version
ID:	243088   Click image for larger version
