Old 05-05-2011, 12:58 AM
68grandprix 68grandprix is offline
Default TH400 driveshaft with yoke needed
My '71 Lemans has a bad vibration that I'm pretty sure is the driveshaft. I used a super long yoke(what I had) which placed the u-joint far from the tailshaft, and had the shaft shortened(swapped in a mid-length tailshaft trans and 8.5 rearend). I think what happened is the long yoke wore the output yoke bushing. I need a shorter yoke and stock driveshaft so I can have it shortened(again) instead of lengthening my driveshaft, which I hear is more difficult and expensive. Any one around SLC in Utah? Thanks, Jim
Sometimes I think about how much more money I'd have if my car got better mileage, but when I hammer the gas and I smell that tire smoke........I remember that I also spend a lot of money on tires.
Old 05-05-2011, 07:18 AM
chrisp chrisp is offline
Have all that you need , send a pm with email for pictures etc. As far as the insertion of the yoke , i usually go all the way in then back it out 1" then measure for the shaft .thanks
Old 05-08-2011, 11:10 PM
Thanks Chris, but I'm looking for something nearby. Jim
Old 05-09-2011, 05:49 AM
If you just need a good short 400 turbo yoke i can send just that and you can have another D-shaft shortened .
