Old 05-07-2011, 08:11 PM
TATA79 TATA79 is offline
Default HEI BAT wire
Okay guys I'm stumped. I have an idea but need someone to bounce this off of. 79 TATA, 403.... Brought the car back to life after sitting a couple years. I had zero spark, I checked the HEI BAT wire, pink, and when disconnected from the distributor it has 12 volts. If I plug it in and measure for voltage with the lid to the coil off I have 6.5-7 volts..... I ran a 12 volt jumper and the car starts and runs great, turn the key off of course nothing happens until I disconnect my jumper. Now the really odd thing is that this is intermittent. For a little while today, I needed no jumper and the car ran great. I checked the resistance and the negative cable found no issues, even dropped the column to examine the ignition switch for burns. As I can tell from the diagrams, it appears that the pink wire comes straight from the ignition switch. Any help would be amazing
Old 05-11-2011, 05:18 PM
Default Stumped
Anybody? I can't figure this out still. Ignition switch?
Old 05-12-2011, 01:35 AM
GStage1's Avatar
GStage1 GStage1 is offline
Your copper contact bars inside the ignition switch are carbon fouled....get a new ignition switch.....make sure you get the correct one....tilt and non-tilt use different switches.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 05-12-2011, 01:20 PM
This is the switch on the column under the dash.
(not the key switch)
Old 05-12-2011, 06:32 PM
GStage1's Avatar
Yes, ignition switch on the column....NOT the key cylinder.
Inside the ignition switch are many copper bars and small coil springs....when the copper bars get fouled they don't make a good connection with the contacts.
George Nenadovich
Old 05-12-2011, 09:16 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
Correct me if I'm wrong but isn't the HEI wire brown? I think you are hooking up to the Tach wire?
_____________________________
www.classicpontiacrescue.com
Old 05-20-2011, 09:52 PM
Default No, at least this one is pink
On this vehicle the pink wire has switched power, it is right next to the tach signal which is brown. The pink hei wire is closer to the firewall and the tach filter is closer to the carb.
